55 příspěvků
WiFi Manager Premium
10. 02. 2012 01:52
WiFi Manager Premium v2.1.7
Požadavky: for all Android versions
Popis: An easy way to manage Wifi connections. Includes beautiful widgets.
Find, connect, manage WiFi networks. Improve connection quality with a graphical channel radar. Discover open networks around you.
Jedná se o tu aktivovanou verzi !
https://market.android.com/details?id=org.kman.WifiManager
Download a Instrukce:
http://rapidshare.com/files/1343695922/WiFi_Manager_Premium_v2.1.7.apk
http://www.edisk.cz/stahni/03090/WiFi_Manager_Premium_v2.1.7.apk_579.04KB.html
http://www.uloz.to/12787592/wifi-manager-premium-v2-1-7-apk
http://www.mediafire.com/?71sgv6p8fgm26d4
10. 02. 2012 01:56
Re: WiFi Manager Premium
WiFi Manager Premium v2.1.8
** Crashes after updating? Market bug. Uninstall and reinstall often helps.
2.1.8:
Added Polish and Czech translations.
The 3x1 wiget on 10" tablets now shows connection speed info, like the 4x1 widget on smaller screens.
Sharper graphics for the Galaxy Nexus.
http://www.mediafire.com/?h6mrca687jnuvsg
http://www.mirrorcreator.com/files/1W6WKHVU/WiFi_Manager_Premium_v2.1.8_0.apk_links
http://www.embedupload.com/?d=8RVQAWFAET
http://uploadmirrors.com/download/WXQTDBUU/WiFi_Manager_Premium_v2.1.8.apk
04. 06. 2012 08:48
WiFi Manager Premium v2.5.1
Includes two home screen widgets: one displays detailed connection info, the other lets you switch among your favorite networks with a single tap.
New and improved:
• Better graphics, including a dark color theme;
• Assign your own descriptions and icons to individual WiFi networks - never forget what that "XYZ1234" network is;
• Switch among your favorite networks with a single tap by using the WiFi Network Switcher widget. It will even enable WiFi if needed.
• Automatic switching between fixed and dynamic (DHCP) IP addresses (Android Settings can't do this);
• Still there - support for tablets in landscape mode.
Urgent fix for widget widths on Android 1.6-2.1
2.5.0:
Two new widget themes, styled after Android 4.0 (part of premium package).
IP address and proxy server configuration for Android 3.0 and 4.0 (free).
Widget to toggle WiFi Tethering
Support for EAP (802.11x) networks, Android 2.2 and higher.
A new way of connecting to networks, keeping all networks active. See app settings
Note: Enabled premium functions.
These features are: advanced per-network options (desciption, icon, IP address) and the one-tap network widget.
All the other - essential - features are free: the black widget with detailed connection info (both sizes), scanning and connecting to networks, the network list view, the network signal radar.
http://www.MegaShare.com/4303971
http://uploadmirrors.com/download/PPF3O5QM/w251.zip
http://directmirror.com/files/D7AHQMIL
06. 06. 2012 07:54
WiFi Manager Premium v2.6
New widget theme (free): like old but with blue icons.
http://www.MegaShare.com/4308849
http://uploadmirrors.com/download/1GQI803C/wp26.apk
http://directmirror.com/files/1TGWKZUD
19. 07. 2012 09:25
WiFi Manager Premium v2.6.4
Požadavky: Android v2.1+
Fixed crash when adding a network fails.
Recent:
A setting for widget toggle switch action: immediate / confirm / ignore.
Tap signal level in the main app to switch modes (image / percent / dBm).
Two new premium widget themes, styled after Android 4.0.
https://play.google.com/store/apps/details?id=org.kman.WifiManager
http://www.MegaShare.com/4398236
http://uploadmirrors.com/download/0M95IIYV/2w6a4s.apk
http://directmirror.com/files/OZZ8SNP1
11. 08. 2012 16:20
WiFi Manager Premium v2.6.6
Recent changes:
*** Crashes after updating? Uninstall / reinstall often helps.
2.6.6
Fixes for Android 4.1
New, improved Czech translation.
New Portugese translation.
Less description »
http://www.directmirror.com/files/XGJC3ML8
26. 09. 2012 00:44
WiFi Manager Premium v2.6.7
- Added "sticky broadcast" permission which is not needed, but there are firmwares who think it is, and crash the app.
http://www.embedupload.com/?d=8LQJIVEXKZ
26. 04. 2013 17:25
WiFi Manager Premium v2.6.8
Fixed compatibility of the one-tap switcher widget with Android 4.1-4.2
Added Portuguese-Brazilian translation.
http://uloz.to/xVVEjHSA/wifi-manager-premium-v2-6-8-apk
https://mega.co.nz/#!vwJ0gSjD!VXAYlQkplGGRisCNkzRZI0x7QSk-yvMGxazVtvgCVgA
http://www62.zippyshare.com/v/63728807/file.html
06. 09. 2013 16:04
WiFi Manager Premium v2.6.14
- na GP se zatim neuvadi
http://uloz.to/x5sZZptg/wifi-manager-premium-v2-6-14-4allmobile-eu-apk
https://mega.co.nz/#!44EyyRiY!SPwOUXgZAdXk21RhfFrCJS-xIUAA2afaxUSTx2X9-38
http://www38.zippyshare.com/v/94053217/file.html
09. 09. 2013 03:59
WiFi Manager Premium v2.7.0
v2.7.0
New feature: scan for and switch to best network (among already configured). Disabled by default, please see app settings.
Fixed EAP (802.11x) networks on Android 4.3.
Added a setting for "exit" button: disable WiFi or not.
Fixed "open first" network sorting.
An option to show detailed WiFi state in a status bar notification, off by default, see app settings.
High res graphics for Full-HD phones (Samsung S4, etc.)
http://uloz.to/xzK6uvwJ/wifi-manager-premium-v2-7-0-4allmobile-eu-apk
https://mega.co.nz/#!A1FEVCRD!NDSMYiLQt3Sshn-I_kSUe2xZ0M8_PfSYufYDipR-iaM
http://www24.zippyshare.com/v/62448968/file.html
55 příspěvků
