ElectroDroid [Donate] v2.6
Požadavky: Android 1.6+
ElectroDroid is a simple and powerful collection of electronics tools and reference; it includes:
• Resistor color code decoder (3-6 bands, with inverse look-up);
• Inductor color code decoder;
• Ohm’s law calculator;
• Reactance calculator;
• Voltage divider;
• Resistor ratio, value/series/parallel;
• Capacitor charge calculation;
• Operational amplifier;
• LED resistor calculator;
• LM317 calculator;
• Heat dissipation;
• Battery Life calculator;
• Inductor design tool;
• Voltage Drop calculator;
• PCB Trace Width calculator;
• Simple Filters calculator;
• NE555 astable calculator;
• Port pin-out (USB, Serial, Parallel, Ethernet, SCART, DVI, HDMI, S-Video, VGA, FireWire, Jack, XLR, RCA, DMX, ATX, Molex, EIDE, SATA);
• Resources (Resistivity table; Table of standard resistors and capacitors; Capacitor marking codes; AWG and SWG Wire size; Ampacity Table; Symbols and Abbreviations; Circuit Schematic Symbols; SI Units prefixes; Battery info; Boolean logic gate and algebra Theorems; 7400 info and pinout; ASCII code);
• Full support for EIA resistor series for all caluculators;
...and more to come!
• Differential Amplifier;
• LM317 current calculator;
• NE555 monostable mode;
• Resonance calucator;
• 3oz in pcb trace calculator;
• New resources: radio frequency;
• New translation: Romanian;
• bugs fix;
https://market.android.com/details?id=it.android.demi.elettronica.pro
http://www.2shared.com/file/DCVRrape/ed26.html
http://uploadmirrors.com/download/A0N9LNEO/ed26.apk
http://www.mirrorcreator.com/files/YVZJ11J6/ed26.apk_links
