SD Maid - System Cleaning Tool v2.0.0.0 + SD Maid Pro 1.5.2-Unlocker
Požadavky: Android 1.6+,THIS APP IS INTENTED FOR ROOTED DEVICES! Without root functionality is limited.
@Common
- Complete new UI (ActionBar+Fragments+ViewPager)
- Rewritten alot of the backend code, making the code cleaner and more straight forward
- Added smarter partition detection
- Tidied log outputs
- Fixed possible bug in root detection
- Updated translations
@Startpage
- New greeting picture
- Added advanced partition view
@Explorer
- Simplified code and improved browsing speed
- Removed context menu in favor of ICS style actionbar menu
- Made a more user friendly permission dialog
- Better SendTo compatibility
- Nicer refresh, dir up
@Searcher
- Improved speed
- Removed rename,delete context menu option
- Deactivated autocomplete
- Improved JellyBean compatibility
@AppControl
- Improved compatibility with JellyBean
- Added smart permission detection for better compatibility with some ROMs
@CorpseFinder
@AppCleaner
- Fixed a rare case where not all files are deleted
@Duplicates
- Worked on performance, especially for low mem devices
- Added experimental feature AutoSelection (see advanced settings)
- Fixed FC when usb storage was mounted
- Improved progress display
@BiggestFiles
@SystemCleaner
- Added entry 'Bugreport files' (Thanks to Jeff Kosowsky)
https://play.google.com/store/apps/details?id=eu.thedarken.sdm
https://play.google.com/store/apps/details?id=eu.thedarken.sdm.unlocker
http://uploadmirrors.com/download/04TIDJMS/sdm20.zip
http://directmirror.com/files/06ARNIE3
