Tape-a-Talk Pro Voice Recorder
30. 12. 2012 16:59
Tape-a-Talk Pro Voice Recorder v0.9.8.1.1
(98,- Kc)
Pozadavky: Android 2. a vyssi
Popis: Tape-a-Talk Pro is a high quality (Wave) voice recorder with many extra features
0.9.8.1.0: Added improved Repair function, added dark theme, added sort option for recordings.
0.9.8.1.1: Fixed corrupt wave header problem
https://play.google.com/store/apps/details?id=name.markus.droesser.tapeatalkpro
http://uloz.to/xWaYrAM/tape-a-talk-pro-voice-recorder-v0-9-8-1-1-apk
http://www73.zippyshare.com/v/60477684/file.html
http://www.directmirror.com/files/DEIWP1V4
Tape-a-Talk Pro is a high quality voice recorder designed for simplicity and is able to record voice notes/voice memos/audio even when the display is off.
ADDITIONAL features of this PRO version compared to the free version:
- Sort Recordings by Name (Ascending, Descending)
- Dark or Light Interface Theme
- Nicer interface and "big buttons"-mode
- Choose custom storage directory.
- Define custom dynamic filename scheme. Use predefined variables like day, month, hour, minute, seconds.
- Quick rename and send after recording: You can choose to enable the automatic appear of a fast rename&send window after record.
- Set custom default mail settings (subject, recipient and text). No need to enter mail adresses every time!
- Fast forward/Rewind during recordings. Your phone becomes a dictation machine!
- Cut recordings: Cut out what you don't like with a few clicks.
- Widget: Now you can start, pause and stop recording via the widget on your homescreen (see screenshot). To add the widget to your homescreen, simply Long-Click on your homescreen, choose "Widgets -> Tape-a-Talk Pro".
- Repair recordings (Note: this does not fix recordings with noise or other problems. It just fixes the header of the file to make it playable)
21. 02. 2016 22:58
Re: Tape-a-Talk Pro Voice Recorder
Tape-a-Talk Pro Voice Recorder v1.0.0.5
- added easier way to use SD card
https://revclouds.com/1u4plphuuk1j
https://uploadshub.com/zopcg86s9wl0
https://userscloud.com/hlwf5aam6sct
http://ul.to/lqsvm4dt
11. 04. 2016 14:35
Tape-a-Talk Pro Voice Recorder v1.0.0.6
fixed static sound after pause
http://ulozto.cz/xaom4Ktn/tape-a-talk-pro-4allmobile-eu-d-apk
http://ulozto.sk/xk1sLnDP/tape-a-talk-pro-4allmobile-eu-d-apk
http://ulozto.net/xF7obaBQ/tape-a-talk-pro-4allmobile-eu-d-apk
https://webshare.cz/file/3lj4f975k4/tape-a-talk-pro-4allmobile-eu-d-apk
23. 05. 2017 03:26
Tape-a-Talk Pro Voice Recorder v1.2c
65,-Kc
Požadavky: Android: a 2.1vyšší
Co je nového: added explanation dialog after startup.
https://ulozto.cz/!JSrl7owlFBJt/tape-a-talk-pro-voice-recorder-apk
https://webshare.cz/file/3wD2kd3nn7/tape-a-talk-pro-voice-recorder-apk
15. 08. 2018 19:48
Tape-a-Talk Pro Voice Recorder v2.0.6 [Paid]
60,-Kč
v2.x adds Cloud upload feature, WiFi transfer, design updates, bugfixes and more!
v2.0.6. bugfixes, e.g. the widget works again.
https://uploadocean.com/xo6zqp2pi4dj
https://upload4earn.org/y3qh3wxpul3s
https://douploads.com/nu35bfdtf3ef
http://speed4up.com/1be171a7fe8a8595
http://ul.to/2xetcp39
25. 11. 2019 10:56
Re: Tape a Talk Pro Voice Recorder
Tape a Talk Pro Voice Recorder v2.0.8 [Paid]
95,-Kč
Opraveno sdílení po aktualizaci cílové SDK 27.
Přidána možnost rozděleného průběhu v nastavení pohledu.
Přidána možnost měnit jazyky.
Opravy překladů.
https://uploadocean.com/8kbyjynh55gr
https://upload4earn.org/6qxrump48sas
http://businessnewscurrent.online/r0jsl3jxbke9
https://douploads.net/6gpft7ex7mbm
http://speed4up.com/25eacb7b70f9a836
http://ul.to/aq0v4eyl
