10. 05. 2014 00:36
IPTV Pro
IPTV Pro v2.7.1
(49,- Kc)
Popis: Watch IPTV from your Internet service provider or free live TV channels from any other source in the web.
v2.7.1
- Default channel icon changed
- Fixed bug with loading some xspf playlists
- Minor bug fixes and improvements
Vice info:Kód: Vybrat vše
https://play.google.com/store/apps/details?id=ru.iptvremote.android.iptv.pro
Stahuj zde:Kód: Vybrat vše
http://www12.zippyshare.com/v/38874541/file.html
https://www.tusfiles.net/o66hfuwyj2t8
http://hugefiles.net/mhnrj70mtemw
http://bit.ly/1hDc3cR
http://rapidgator.net/file/1e56ac86bee70fba538b73cbc426b0d9
Pro features (comparing with free version):
✔ Ad free
✔ Ability to auto-reconnect to streaming server when connection is closed unexpectedly (http streams only).
✔ Start app on device boot option, useful for set-top boxes.
✔ Extended playlists history
If you are using VLC to watch TV on your PC then this app is for you.
✔ M3U and XSPF playlists support
✔ Playlists history
✔ Playing multicast streams with UDP proxy (proxy need to be installed in your LAN)
✔ Grid or list view of TV channels
Setup instructions:
* First you'll need to input channels list (m3u or xspf playlist), you can get it from your ISP or find free channels list in the web.
* If app asks to setup UDP proxy, please do it, see instructions below.
15. 06. 2014 20:24
IPTV Pro v2.7.1 Patched
http://www.tusfiles.net/qk1l4ii2o1bc
http://filecore.co.nz/r1bt46gitnvt
http://www32.zippyshare.com/v/67764662/file.html
17. 06. 2014 10:37
IPTV Pro v2.8.0
New players support: GoodPlayer, Wondershare Player
http://www16.zippyshare.com/v/64389483/file.html
https://www.tusfiles.net/ml0k66i29vep
http://hugefiles.net/okzmbi1zv31p
http://www.datafilehost.com/d/e24c723c
http://unlimitzone.com/iz4d3fc4h3a0/iP.zip.html
http://rapidgator.net/file/d211d77742a8c70443cd954dcb675648
IPTV Pro v2.8.0 Patched
https://www.tusfiles.net/hsrgavuttker
http://fcore.eu/n5wekgjw563f
http://www.2shared.com/file/t9StPSTj/IPTVProv280b25x-signed.html
29. 08. 2014 00:58
IPTV Pro v2.10.0 +Patched
co je nového:
UI for managing custom EPG sources
Slovenian and Lettish localizations
Bug fixes
https://play.google.com/store/apps/details?id=ru.iptvremote.android.iptv.pro&hl=en
Patched
http://unlimitzone.com/ehsx9kivaln1
https://www.tusfiles.net/zpmy7jjg0byf
https://webshare.cz/group/42x6bM7P1f/
http://ulozto.cz/x3nvRKMs/iptv-pro-v-2-10-0-b-27-ck-apk
http://ulozto.net/x6SvuWo4/iptv-pro-v-2-10-0-b-27-ck-apk
Original: (Need Modded Google Play)
http://unlimitzone.com/9fapb12au1dy
https://www.tusfiles.net/w7he39ni58zc
https://webshare.cz/group/uq9t65r3nN/
http://ulozto.cz/xFBntbpc/iptv-pxx-2-10-0-build-27-apk
http://ulozto.net/x6HsrEZa/iptv-pxx-2-10-0-build-27-apk
07. 09. 2014 17:47
IPTV Pro v2.10.2
New translations for languages: Croatian, Dutch, Estonian, Italian, Lithuanian, Portuguese, Serbian and Turkish.
Patched version
http://fileinz.com/elo3nn7xi7js
https://www.tusfiles.net/o9ffiviga64t
http://unlimitzone.com/cvcijlnwg8u8
http://uploaded.net/file/srsl4k7q
Original version (Modded Google Play it needed)
http://fileinz.com/jsqqmn342p47
http://www.2shared.com/file/OTj3_nfF
https://www.tusfiles.net/cwhmn7gr4ikw
10. 10. 2014 18:43
IPTV Pro v2.10.3 Patched
New translations for languages: Czech, German, Romanian, Spanish, Ukrainian.
https://www.tusfiles.net/fpgo1ladmutq
http://uploaded.net/file/sfc1ecgr
http://www.2shared.com/file/6anp8GAo
http://unlimitzone.com/plym3jyi644x
http://uloz.to/xmGKyHMs/iptv-pro-v2-10-3-patched-apk
https://webshare.cz/file/6xc43r73s7/iptv-pro-v2-10-3-patched-apk
15. 11. 2014 22:31
IPTV Pro v2.12.1
Fixed issue with loading playlist after updating the app from 2.6.0 and earlier versions.
Support 'tvg-id' attribute in m3u playlists
Original versionKód: Vybrat vše
https://www.tusfiles.net/90gftisqowkc
http://www.2shared.com/file/Y0DAIS8h
http://uploaded.net/file/3h5eb7ir
http://uloz.to/xuB2pJUb/iptv-pro-v2-12-1-original-apk
https://webshare.cz/file/6y4587e76b/iptv-pro-v2-12-1-original-apk
Patched versionKód: Vybrat vše
https://www.tusfiles.net/dvim569ht2xf
http://unlimitzone.com/sqcolve24qoa
http://uloz.to/xviPZzV5/iptv-pro-v2-12-1-patched-apk
https://webshare.cz/file/3Vl3OZ5a13/iptv-pro-v2-12-1-patched-apk
30. 12. 2014 14:18
IPTV Pro v2.13.2
Added leanback launcher for Android TV
OriginalKód: Vybrat vše
https://www.tusfiles.net/7239vxhkaicl
http://uloz.to/xZg1bVbB/iptv-pro-v2-13-2-original-apk
https://webshare.cz/file/3y62rh5232/iptv-pro-v2-13-2-original-apk
PatchedKód: Vybrat vše
https://www.tusfiles.net/ggghel02i2zm
http://uloz.to/xUY8U9Ub/iptv-pro-v2-13-2-patched-apk
https://webshare.cz/file/6251iO6pP2/iptv-pro-v2-13-2-patched-apk
14. 12. 2015 13:24
IPTV Pro v3.0.2 Patched
Fixed compatibility issue with MX Player Pro 1.8.1
Playlist parsing improvements
http://uloz.to/xCLXzy7U/iptv-pro-v3-0-2-patched-apk
https://revclouds.com/s7bs5xxse38e
https://uploadex.com/ee4ahrfov3qv
https://dailyuploads.net/vaqfskk8isgo
http://unlimitzone.com/lmw0axy27ipo
http://ul.to/qzzur1zr
29. 12. 2015 15:16
IPTV Pro v3.0.3 Patched
- Stability improvements and bug fixes
http://uloz.to/xWiuv5cu/iptv-pro-v3-0-3-patched-apk
https://revclouds.com/zgaxztrn6ftz
https://uploadex.com/3c8iqwnv3zzc
https://dailyuploads.net/n8nsvnf69f3i
http://unlimitzone.com/hp8noy3b1nzf
http://ul.to/z6d4xood
