08. 06. 2014 03:10
3D Sense Clock & Weather
3D Sense Clock & Weather v0.41
požadavky: android 1.6
popis: 3D Sense Clock & World Weather is a full featured, size 4x1, 4x2 and 5x2 fully customizable digital clock and weather forecast widget.
screen:
info:
https://play.google.com/store/apps/details?id=com.droid27.d3senseclockweather
stahuj:
http://ulozto.cz/x27pLHNf/3d-sense-clock-weather-zip
http://ulozto.net/x8LDxpQT/3d-sense-clock-weather-zip
http://ulozto.sk/xGEognDp/3d-sense-clock-weather-zip
The widget features the following:
- World weather forecast application (no need to add a widget if you don't want to; you can check out the weather forecast by opening the application)
- 3 widget sizes; 4x1, 4x2 and 5x2(for Galaxy Note or tablets)
- 12 skins to choose from
- Support for external theme packs containing even more skins (theme packs can be downloaded separately)
- 3 weather icon skins
- 6 fonts for the time
- 10 battery icon themes
- Portrait or landscape mode
- 12 or 24 hour clock with date
- Display of current week number
- Supports dynamic location (optional) - use this to automatically update your location and receive weather forecasts as you travel
- Weather conditions for current location (condition and temperature, low and high temperatures and weather icon)
- Detailed weather forecast display including the following:
- Local time
- Sunrise and sunset time for current location
- Humidity and wind conditions
- Current condition, temperature and low and high temperatures
- Current condition icon
- Last weather update time
- 4 day weather forecast
- World weather: Choose to display weather information for any number of different locations worldwide. Just select your favorite locations and you will immediately have updated weather and time information.
- Launch up to four different applications by tapping different widget hotspots (is user defined)
The widget can be fully customized with the following options:
- Choose the widget and weather icon skins
- Choose the text color for the time, am/pm indication, date, location, current weather condition, current temperature and hi/lo temperatures
- Display shadow on the time
- Choose the font for the time
- Display 12 or 24 hour time with optional AM/PM indicator (if 12 hour format)
- Beep every hour (optional)
- Select the date display format
- Display a manually selected location's time instead of phone's time
- Optionally show or hide specific elements of the widget (hi/lo temperature, weather update time, am/pm indicator, battery status, next alarm, etc)
- Use current location to display weather info or specify any location you want
- Get location updates from the network (cell/WiFi) or your GPS
- Display temperature values in Celsius or Fahrenheit
- Optionally display the next alarm (under the hour)
- Select automatic weather refresh period (15 minutes, 30 minutes, 1, 2, 3, 4 or 6 hours)
- Enter your favorite world locations to watch local times, current weather conditions and weather forecast information
- Update weather on WiFi and/or GPRS
- Choose whether you want to update while roaming or not
- Play notification sounds on location and weather changes and updates
- Select what application to launch when tapping the hours
- Launch more applications by tapping the weekday or month
- Optionally display the battery level
- Specify how to receive location updates (how often and for how much distance)
- Select alternate weather forecast service Naposledy upravil(a)
milann70 dne 08. 08. 2014 18:19, celkem upraveno 1 x.
08. 08. 2014 18:15
3D Sense Clock & Weather - 0.75.05
https://webshare.cz/group/6qM7di12m6/
http://www78.zippyshare.com/v/42213562/file.html
http://ulozto.cz/x7YgUhSA/3d-sense-clock-weather-0-75-05-apk
07. 04. 2017 19:12
3D Sense Clock & Weather v1.67.01
2.3 a vyšší
Oprava chyb.
https://ulozto.net/!FTjETbXlwB8e/3d-sense-clock-weather-1-67-01-4allmobile-eu-apk
https://webshare.cz/file/5Y64zb436z/3d-sense-clock-weather-1-67-01-4allmobile-eu-apk
milann70 dne 20. 12. 2018 04:29, celkem upraveno 1 x.
05. 09. 2018 13:33
3D Sense Clock & Weather v4.37.02 [Premium]
4.0 a vyšší
- Přidána podpora živých tapet
- Zlepšení denních a hodinových předpovědních karet
- Používejte vybrané jednotky uživatele v radarové legendě
- Oprava chyb
Stahuj zde: Premium features Unlocked
https://douploads.com/71y0t9ys91of
https://upload4earn.org/5s0117a1h3xm
https://uploadocean.com/oq5da9ro7hzs
https://webshare.cz/file/4jtgx4o83o/3d-sense-clock-weather-v4-37-02-premium-apk
20. 12. 2018 04:38
3D Sense Clock & Weather v4.91.02 [Premium]
4.1 a vyšší
- Optimalizace pro Android 8+
- Změny a optimalizace widgetů (optimální využití baterie podle pokynů pro systém Android 8+)
- Indikátor odstraněné baterie - není podporován v miniaplikácích zaměřených na platformu Android 8+
- Přidána ikona obnovení počasí na widgety (nahrazena předchozí hot spot)
- Změny nastavení (odstraněné zastaralé nastavení)
- Vylepšená (zjednodušená) hlavní nabídka
- Přidána možnost nastavení na panelu nástrojů
- Oprava chyb
https://play.google.com/store/apps/details?id=com.droid27.d3senseclockweather&hl=en
Stahuj zde: Premium features unlocked
https://uploadocean.com/hnuyeh2xq8g8
https://douploads.com/okgdbucntbbg
https://uloz.to/!ZkTJ4hHVxoXt/3d-sense-clock-and-weather-premium-apk
https://webshare.cz/file/784hk6CP2b/3d-sense-clock-and-weather-premium-apk
22. 05. 2019 16:31
3D Sense Clock & Weather v5.20.04 [Premium]
4.1 a vyšší
- Nová možnost přepínání hodin denně s denními předpovědními kartami
- Nový graf rosného bodu na stránce hodinových grafů
- Nová možnost využití hodinové prognózy pro aktuální podmínky
- Přidána možnost animovaného radaru s podporou různých vrstev, minulé i budoucí prognózy (premium)
- Mnoho vylepšení uživatelského rozhraní a oprav chyb
https://www.uploadship.com/12357ed7a776c7e9
https://uploadbyte.com/xpnwy39ste69
https://uploadrar.com/tuvrp30wjju5
https://dropapk.com/pxda01afkhsx
https://douploads.com/9v5x6twnzsrw
30. 05. 2019 10:32
3D Sense Clock & Weather v5.20.05 [Premium]
4.1 a vyšší
oprava chyb
https://www.uploadship.com/ee41014a5e4c5514
https://uploadrar.com/jk0jyidz4430
https://uploadbyte.com/4b9c7oo7t8g1
https://douploads.com/929okkqs581y
06. 06. 2019 09:15
3D Sense Clock & Weather v5.20.06 [Premium]
4.1 a vyšší
oprava chyb
https://uploadrar.com/sp0idvbb3870
https://uploadbyte.com/ctcp6q9etyzo
https://douploads.com/b88enxer8gzq
https://dropapk.com/g13tcqscteql
https://www.uploadship.com/4b41ce7766f6d7ba
12. 06. 2019 09:56
3D Sense Clock & Weather v5.20.07 [Premium]
4.1 a vyšší
oprava chyb
https://uploadrar.com/mun6bcg6zdfv
https://dropapk.com/3hmb2q9j0jf7
https://uploadbyte.com/o0g8b1pozslr
https://douploads.com/tvxdq0c2g9ol
https://www.uploadship.com/0e1a2000f0ab81a0
13. 06. 2019 02:23
3D Sense Clock & Weather v5.25.03 [Premium]
4.1 a vyšší
oprava chyb
https://uploadrar.com/qbeh5tkpna4b
https://dropapk.com/3ti98rxnqs67
https://uploadbyte.com/9y50tz0b6y48
https://www.uploadship.com/c42cecc9318fbd39
