Pozadavky: Android 2.3.3 a vyšší Popis: Have you seen the International Space Station? It is visible with the naked eye!
If you like space or astronomy, you will like this ISS tracker app.
v2.00.44:
- Weather data fixed for the Netherlands
- Language files updated
- Small bug fixes
v2.00.62:
- Dates are now correct in the 'Share sighting' text
- Fix for Comet magnitude and path errors
- Iridium Flare point on ground track
- Included Maidenhead Grid Locator in Amateur Radio Extension
- Fix for crash at refresh
Pozadavky: Android 2.3-5.0 Popis: Have you seen the International Space Station? It is visible with the naked eye!
If you like space or astronomy, you will like this ISS locator app.
- The Comets and Planets Extension can now detect Planets
- The satellite selection list for Famous Objects and Amateur Radio Satellites is not alphabetically sorted and searchable
- Some design changes to move towards Material Design (Android 5.0)
ISS Detector will tell you when and where to look for the International Space Station or Iridium flares. You get an alarm a few minutes before a pass. You will never miss a pass of the International Space Station and you will never miss the bright flashes of the iridium communication satellites. ISS Detector will also check if the weather conditions are right. A clear sky is perfect for spotting.
Extensions will enhance the functionality of ISS Detector. With an in-app purchase you can add comets and planets, amateur radio satellites and famous objects, like the Hubble space telescope or the Chinese space station Tiangong.
• Overview of the coming passes
• Weather conditions for perfect sightings
• Radar screen with path indication
• Current location on a map
• Detection of Iridium flares
• Notifications and Alarms
• Share sightings with whatsapp, twitter, gmail, email etc.
• Automatic location and timezone detection
• Widget
• Dedicated tablet layout
Available Extensions (in-app purchase):
Radio Amateur Satellites
Track dozens of ham and weather satellites
Famous Objects
Track Hubble, X-37B, Fitsat, Tiangong and more
Comets and Planets
Track comets as they come closer to earth. Perfect for C/2011 L4 Panstarrs in March 2013 or C/2012 S1 ISON in November 2013.
Enable ISS Detector to display the positions of the planets on the radar view.
ISS Detector combines data from Nasa, Heavens-above.com, minorplanetcenter.net and weather from yr.no.
ISS Detector Satellite Tracker v2.00.92 (Extensions Unlocked)
- Widget correctly handles 'no sighting' messages
- Better layout for small screens
- New backend server for Extensions Satellite data
- Show the progress of the current passes in the list
ISS Detector Satellite Tracker v2.00.94 (Extensions Unlocked)
ISS Detector Satellite Tracker v2.01.22 (Extensions Unlocked)
- New color design and new icons
- Day and night overlay on the map
- Better detail names for Iridium flares
- Secure server connection where possible
- Fix for Russian timezones
