09. 10. 2016 14:44
Parrot - Voice Recorder Pro
Parrot - Voice Recorder Pro v2.1.2 [Unlocked]
PRO Features Unlocked l Lifetime Subscription l Drive Works
Pozadavky: Android 4.4 a vyssi
Popis: Parrot is a voice recorder app which allows you to Record, Play and Share voice recordings, all within 3 taps!
- Added a source verification test for phone calls
- Small UI fixes and tweaks
Vice info:Kód: Vybrat vše
https://play.google.com/store/apps/details?id=com.SearingMedia.Parrot
Stahuj zde:Kód: Vybrat vše
http://www13.zippyshare.com/v/024K3img/file.html
https://userscloud.com/qm82y88haxya
https://tusfiles.net/couorohh0b8i
Parrot is a voice recorder app which allows you to Record, Play and Share voice recordings, all within 3 taps! A simple and beautiful user interface helps you create crisp and balanced voice recordings. Use Parrot as a dictaphone and start recording voices, audio, phone conversations, your singing: anything you like, in HD!
Record yourself or any voice message in high quality with the best dictaphone for Android. Download Parrot, save your first voice memo today, and start being more organized.
Parrot Pro (available as in-app purchase) allows you to Record Phone Calls, Schedule Recordings for a specific time and date and synchronize your tracks to the cloud using Google Drive or Dropbox.
Parrot is has no time limits or no functionality limits. With over 100 different setting combinations, you can finely tune your recordings and playback.
Parrot Pro - In-app Purchase
• Phone Call Recording: Record incoming or outgoing phone calls either automatically or by prompt before or after the call.
• Scheduled Recordings: Schedule a recording for a specific date, time and duration.
• Cloud Backup: Easily synchronize all your files individually or as a zip to Google Drive, Dropbox or anywhere on your device.
Parrot Basic - All Users
• Record: Create voice recording with a live and buttery smooth sound wave graph as you record to help you easily identify when you’re receiving the right levels. Record using the standard mic, camcorder mic or even a Bluetooth microphone.
• Play: Playback your voice recordings with a simple and beautiful list that helps you easily identify tracks with intuitive calendar icons as well as playing and paused animations.
• Share: Share your tracks with your favorite apps with two simple taps. Your favorite apps are saved to allow you to quickly share in the future.
• Notifications: We’ve included simple and easy notifications in order to allow you to use Parrot and continue to work in the background.
• Android Wear: Manage your recording and playback right from your wrist.
Recording Options (Dictaphone options)
• Quality: Recording in WAV and MP4 formats. Choose your sample rate and bit rate.
• Source: Record your voice from your device mic, camcorder mic or Bluetooth headset.
• Effects: Use Android’s built-in recording effects to remove background noise, cancel out echo and automatically control gain. For those situations where more power is needed, set your own custom gain.
• Auto Pause (skip silence): Easily skip silence while recording by having the app pause and restart for you based on time and sound sensitivity thresholds.
• Alerts: Use both vibration and beeps to help you identify when the recording has started and stopped.
Playback Options
• Bass Boost: Boost the bass to help amplify low frequencies of the recordings.
• Volume Boost: Enhance the volume of the track to help hear even quiet noises.
• Preset Reverb: Hear your recording as if it were played in a small room or large hall.
App Permissions
• Record Audio: We need access to your mic to create voice recordings.
• External Storage: We require access to your SD card as this is our preferred location to store your tracks.
• Phone Calls: Parrot Pro mode allows users to record phone calls.
• Wakelock: Used in Parrot Pro to ensure that your phone wakes up for schedule recordings.
• Vibration: We have a setting that allows you to make your device vibrate when you start or stop a recording.
29. 07. 2017 17:46
Parrot - Voice Recorder Pro v2.3.1.120 [Unlocked]
4.4 a vyšší
Co je nového: Pevná stabilita pro uživatele v systému Android 7.1. Omlouváme se za případné nepříjemnosti!
Stahuj zde: PRO Features Unlocked
https://ulozto.cz/!O5RAbPigqAZP/parrot-pro-2-3-1-120-apk
https://webshare.cz/file/36C2S22nw1/parrot-pro-2-3-1-120-apk
27. 06. 2018 18:56
Parrot - Voice Recorder v2.4.3 b174 [Pro]
4.4 a vyšší
Co je nového:Fixed issue on some devices where the play notification would pop up when connecting to a bluetooth device. Various fixes and improvements.
Stahuj zde: PRO features unlocked
http://suprafiles.org/vpjueg585tde
http://cloudyfiles.org/mkboxiksleu1
https://dailyuploads.net/p8u18xzwsnxa
03. 09. 2018 23:26
Parrot Voice Recorder v2.4.4 [Pro]
4.4 a vyšší
Co je nového: Opravena chyba na některých zařízeních, kde by se při připojování k zařízení Bluetooth zobrazovalo oznámení o přehrávání. Různé opravy a vylepšení.
https://play.google.com/store/apps/details?id=com.SearingMedia.Parrot&hl=en
https://douploads.com/ug7y7414kp13
https://uploadocean.com/g7sfjax1yzki
https://uloz.to/!EDAVsPaA7XNJ/parrot-voice-recorder-pro-v2-4-4-apk
04. 09. 2018 05:55
Parrot Voice Recorder v2.4.5 [Pro]
4.4 a vyšší
Henry1
09. 09. 2009 07:54
14. 12. 2018 09:40
Parrot Voice Recorder v2.5.0 PRO
Requirements : ↑4.4
What's New :
v2.5.0
Introducing a new feature to allow you to backup your app settings to our cloud service. Visit the new "My Account" tab to log in and backup your settings today!
More Info :
Download :
https://uloz.to/!scUoqynBEiKD/parrot-voice-recorder-pro-v2-5-0-apk
https://upload4earn.org/cbsnjwk6tduc
03. 01. 2019 13:41
Parrot Voice Recorder v2.5.1 [Pro]
4.4 a vyšší
Představujeme novou funkci, která vám umožní zálohovat nastavení aplikace do služby cloud. Navštivte novou kartu "Můj účet", abyste se mohli dnes přihlásit a zálohovat.
https://douploads.com/zfw2m2z3szj0
https://upload4earn.org/rfw5gbdivcox
https://uploadev.com/am5tiuoi71ec
Henry1
09. 09. 2009 07:54
17. 03. 2019 18:42
Parrot Voice Recorder v2.5.2 PRO
Requirements : ↑4.4
What's New :
v2.5.2
Fixed issue where some users could not share tracks.
More Info :
Download :
https://uloz.to/!afzDdz6z8tzp/parrot-voice-recorder-pro-v2-5-2-apk
https://dropapk.com/wfqg1yqhkguv
Henry1
09. 09. 2009 07:54
10. 06. 2019 05:57
Parrot Voice Recorder v3.0.1 PRO
Requirements : ↑4.4
What's New :
v3.0.1
The top rated voice recorder on Google Play has a big new feature: Waveform.Cloud integration. This is our custom cloud solution that is designed for audio. Automatically store your tracks on the cloud. Stop losing your tracks. You can switch devices or use multiple devices and never have to worry about synching your tracks.
More Info :
Download :
https://uloz.to/!SyulPB857Lc1/parrot-voice-recorder-v3-0-1-pro-apk
https://dropapk.com/vflihbuiyama
Henry1
09. 09. 2009 07:54
04. 09. 2019 07:04
Parrot Voice Recorder v3.1.4 PRO
Requirements : ↑5.0
What's New :
v3.1.4
- Added translations for Portuguese.
- Fixed issue where waveforms would not cache correctly (slow loading).
- Fixed rare crashes throughout the app.
More Info :
Download :
https://uloz.to/file/rti6DK9HIWox/parrot-voice-recorder-v3-1-4-pro-apk
https://dropapk.to/hp6n77k84v67
