16. 12. 2016 03:56
Collateral - Notifications
Collateral - Notifications v3.5.1-4 [Premium]
4.1 a vyšší
Popis: Collateral allows you to create notes and lists that live in your notification area. Use it to remind yourself of important tasks or to create to-do lists that are accessible from anywhere.
https://play.google.com/store/apps/details?id=com.gpvargas.collateral
http://kingfiles.net/h9riz742qtt1
https://dailyuploads.net/5hxcmo5gi65x
http://hulkload.com/za18kt4f5f15
http://ul.to/ufo91tvl
Main features:
• 250+ notification icons
• Edit active/inactive notifications
• Save created notifications for reuse
• Share notification data to other apps
• Share data from other apps to create notifications
• DashClock extension for active notifications (Android 4.2+)
Premium features:
• Sign in with Google to backup/sync notifications
• Add actions to perform tasks from the notification
• Add pictures to display them within the notification
• Add reminders to create notifications at a certain time
• Show a list of favorites when choosing a notification icon
• Change notification color (Android 5.0+)
• Ad-free experience Dotazy na SZ.
08. 08. 2018 14:55
Collateral Create Notifications v5.0 build 273 [Pro]
4.1 a vyšší
Co je nového:• New UI based on the updated Material design
• Improved filter to sort notifications, look for past reminders and search by tags or color
• Add tags to notifications to filter them in the home screen
• Add actions to lists or set an action to appear by default
• List items marked as done will show as strikethrough text
• Tap on a note's picture to open the note in the edit screen
https://uploadocean.com/bqhah4uwxe4z
https://upload4earn.org/kpecg4c30ipz
https://douploads.com/8i3o06lwb9i3
http://speed4up.com/1b5f97e7702adb26
http://ul.to/a5zzg1dg
https://ulozto.sk/!FRDpe82jmIHZ/collateral-premium-v5-0-apk
