28. 12. 2016 03:58
Gentle Wakeup Pro Alarm Clock
Gentle Wakeup Pro Alarm Clock v1.4.8
110,-Kc
4.1 a vyšší
Popis: Wake up gently and refreshed every day. Turn your device into a sunrise simulator and wake up naturally by light. Light leads to biological processes in the body leaving the deep sleep phase and preparing for wake up.
https://play.google.com/store/apps/details?id=com.changemystyle.gentlewakeuppro
https://dailyuploads.net/jh3a24g59i5n
https://openload.co/f/2bY8NakdV1A
https://dropapk.com/svwjnbw1lyp2
http://ul.to/ylum9glk
https://ulozto.cz/!2BofGlgtMb2q/gentle-wakeup-1-4-8-apk
You will have complete control over the wake up process
Start the sunrise 20 minutes before your desired wake-up time and define your personal brightness level at the end. Add slowly increasing sounds of birds twittering and add a device vibration as a backup 5 min after wake up time. Enjoy a nice weather show before you get out of bed
- Alarm Clock: Fully functional alarm clock with repeated alarms and snooze function.
- Gentle sounds: Wake up with different gentle sounds or your favorite music.
- Brightness adjustment: Brightness ist adjusted smartly to not blend in the night.
- Weather forecast: An animated weather show presents you the weather conditions and temperature for the day.
- Individual Wakeup: Get waked up without disturbing your partner.
- Easy and intuitive: All main functions can be accessed by symbols directly from the main screen.
- Soft torch light: Use the soft light to find something in the nighttime without waking up anyone else.
- Portrait and Landscape: Your device can be placed in portrait or landscape mode on your nightstand.
- Autostart: The app starts automatically even if you close it. No additional battery consumption over night.
Stop waking up stressed out by an alarm tone in the morning
In the stone ages noises meant danger from animals or from enemies. We still have this basic instinct in our brains. Start getting awake by light and you will never want to wake up by sounds again.
Next features coming soon:
- Sunset/Sundown simulator slowly fading the sunlight off overtime (sleep timer) to fall asleep gently (lull)
- Nightlight
Explanation of required Android permissions:
- Photos/Media/Files: Access to storage is needed to play your own songs.
- Camera: Access to camera is needed to activate the flashlight. The camera itself is not used.
- Location: Location info is required for weather forecast. Location can also be set manually by searching for a city name.
- Fading sunlight simulator lets the sun rise and set
- Multiple alarms and clocks
- Different ring tones selectable. Music from device or playlist as ringtone selectable.
- Snooze function with time limit so you do not oversleep
- No extreme loud alarm at beginning while still sleeping (increase)
- Vibrating function is fully configurable
- Diplay will illuminate with sunshine slowly for a soft waking
- Device light can be used as a booklight in dark room at night
- Torchlight can be activated as a torch to find something in the nighttime.
- Can be used for a siesta sleep at noon as well
- Enjoy a relaxing nap and miss no timer thanks to led and xtreme alarm clock vibration
- Set ramp time for snoozing in bed
- Helps with time change (daylight saving zone, standard time) and jet lag Dotazy na SZ.
05. 01. 2017 03:01
Gentle Wakeup Pro Alarm Clock v1.5.5 Final
110,-Kc
4.1 a vyšší
Skip next alarm: Skip a repeating alarm in case you wake up earlier. No risk of forgetting to turn alarm on again.
Bufixes
https://dailyuploads.net/ri7q352ffock
https://dropapk.com/ar5egvcx5ydp
http://ul.to/1w03syzu
07. 01. 2017 00:41
Gentle Wakeup Pro Alarm Clock v1.5.6
4.1 a vyšší
Co je nového: Critical Bugfix: Alarm did not fire when device in deep standby over night (without charging cable) on Android 6 and 7. Fixed in newest version.
https://dailyuploads.net/qsjb9yfhf3n6
https://uploads.to/sp0emhr3wfg5
http://ul.to/n87co3en
08. 01. 2017 23:57
Gentle Wakeup Pro Alarm Clock v1.5.7 Final
130,-Kc
4.1 a vyšší
Critical Bugfix: Alarm did not fire when device was in deep standby over night (without charging cable).
https://dailyuploads.net/cwy71bpa7ted
https://dropapk.com/wegxzu8h7l1c
http://ul.to/ewb3531d
11. 01. 2017 20:10
Gentle Wakeup Pro Alarm Clock v1.5.8
- Bugfixes
Vice info:Kód: Vybrat vše
Stahuj zde:Kód: Vybrat vše
https://dailyuploads.net/ciqnae0lpx8i
https://uploads.to/hj1l2zyu7ttm
http://ul.to/aocjvzzn
13. 01. 2017 12:52
Gentle Wakeup Pro Alarm Clock v1.5.9
4.1 a vyšší
Bugfixes.
Please note there is a critical bug in versions lower than 1.5.6: Alarm may not fire in standby mode. Please upgrade to the newest version
https://dailyuploads.net/3iju3060wjas
https://uploads.to/jblcncwijqka
http://ul.to/h3b5rty8
18. 01. 2017 03:37
Gentle Wakeup Pro Alarm Clock v1.6.1
130,-Kc
4.1 a vyšší
Bugfixes.
Please note there is a critical bug in versions lower than 1.5.6: Alarm may not fire in standby mode. Please upgrade to the newest version.
https://dailyuploads.net/c5xepqjwn8kj
https://uploads.to/jllzuzqk85f2
http://ul.to/msh5rwop
23. 01. 2017 20:26
Gentle Wakeup Pro Alarm Clock v1.6.4
4.1 a vyšší
Bugfixes.
https://dailyuploads.net/7jchd6z69417
https://ulozto.cz/!CHV8Ru5Qnrhe/gentle-wakeup-pro-alarm-clock-apk
https://ulozto.sk/!JsjdGAuTQQB6/gentle-wakeup-pro-alarm-clock-apk
https://ulozto.net/!gyEBAeIk125j/gentle-wakeup-pro-alarm-clock-4allmobile-eu-apk
https://webshare.cz/file/5Kg6um2pm7/gentle-wakeup-pro-alarm-clock-4allmobile-eu-apk
28. 01. 2017 11:04
Gentle Wakeup Pro Alarm Clock v1.6.8
4.1 a vyšší
Co je nového: Bugfixes.
https://ulozto.cz/!SPrbhMokTTY0/gentle-wakeup-v1-6-8-4allmobile-eu-apk
https://ulozto.sk/!Yn2voPN4hKux/gentle-wakeup-v1-6-8-4allmobile-eu-apk
https://ulozto.net/!OOd20BQBvBBo/gentle-wakeup-v1-6-8-4allmobile-eu-apk
https://webshare.cz/file/42Z6o36xz2/gentle-wakeup-v1-6-8-4allmobile-eu-apk
08. 02. 2017 20:26
Gentle Wakeup Pro Alarm Clock v1.7.0
4.1 a vyšší
Bugfixes
https://ulozto.cz/!zVig4s48d6VP/gentle-wakeup-1-7-0-apk
https://ulozto.sk/!9Z7Xo6QX63Qc/gentle-wakeup-1-7-0-apk
https://ulozto.net/!kTW2YsLrbFdg/gentle-wakeup-1-7-0-apk
