PDF Converter Ultimate
19. 05. 2017 11:47
PDF Converter Ultimate v1.0 (Unlocked)
Převést dokumenty ve formátu PDF do aplikace Word, Excel, JPG a další, přímo v zařízení Android. Konverze jsou přesné a velmi rychlé, uspořádání je zachováno.
https://play.google.com/store/apps/details?id=com.cometdocs.pdfconverterultimate&hl=en
Stahuj zde: Paid features unlocked
https://ulozto.cz/!bU2wUIBc9PZO/pdf-converter-ultimate-unlocked-apk
https://webshare.cz/file/4Izzx3oF17/pdf-converter-ultimate-unlocked-apk
Easy to use app, and amazing conversion quality makes this app the ultimate converter for your phone. You can convert files from your phone, or files from your favorite cloud services directly within our app. Files are being converted by our powerful servers, and after conversion is done, result is downloaded to your device and files are being deleted from our servers. This also means the app won't burden your processor or RAM, nor it will drain your battery.
• No limit on file size, or number of converted files
• Conversions are fast and accurate
• Scanned and complex documents are converted as well
• Convert your files from Dropbox, Box, Google Drive, OneDrive and more
• Many formats are supported
Supported conversion types:
- PDF to Word
- PDF to Excel
- PDF to PowerPoint
- PDF to Image
- PDF to AutoCad
- PDF to Text
- Publisher to PDF
- XPS to PDF
- Word to PDF
- Excel to PDF
- PowerPoint to PDF
- Text to PDF
- Log to PDF
- RTF to PDF
- JPG/JPEG to PDF
- BMP to PDF
- PNG to PDF
- GIF to PDF
- TIF/ TIFF to PDF
- OpenOffice Writer ODT to PDF
- OpenOffice Impress ODP to PDF
- OpenOffice Calc ODS to PDF
- MHT/MHTML to PDF
20. 05. 2018 14:03
Re: PDF Converter Ultimate
PDF Converter Ultimate v1.0.16 [Unlocked]
Skener dokumentů - pomocí fotoaparátu můžete převést dokumenty s optimalizovanou kvalitou skenování do formátu PDF, Text, Word nebo Excel
Image Cropper - oříznutí obrázku před jeho převodem do formátu PDF.
Zlepšení kvality a konverze.
https://uloz.to/!AiUOztJZ8xqw/pdf-converter-ultimate-v1-0-16-unlocked-apk
https://ulozto.sk/!3Is9zip0XFlh/pdf-converter-ultimate-v1-0-16-unlocked-apk
23. 06. 2018 13:54
PDF Converter Ultimate v1.0.18 [Unlocked]
Document Scanner - use your camera to convert documents with optimized scan quality to PDF, Text, Word or Excel
Image Cropper - crop your image before converting it to PDF
Performance and conversion quality improvement
https://douploads.com/h3sytoo90116
http://suprafiles.org/86h5iyf4ad4i
