10. 06. 2017 02:54
360 Security Free Antivirus,Booster,Space Clean
360 Security Free Antivirus,Booster,Space Clean v4.1.6.6372
4.1 a vyšší
Popis:Chraňte své mobilní zařízení pomocí aplikace 360 Mobile Security, která je špičkovou aplikací pro zabezpečení mobilních telefonů určenou k ochraně vašeho telefonu před nejnovějšími viry, malware, zranitelnostmi systému a úniky dat.
https://play.google.com/store/apps/details?id=com.qihoo.security&hl=en
https://ulozto.net/!RoMIrvszQiR4/360-security-antivirus-boost-apk
https://webshare.cz/file/47X7cE74a5/360-security-antivirus-boost-apk
Free Security Protection and Speed Booster for Android Phone
Trusted by 200 million users, 360 Security is the only all-in-one speed booster and antivirus app that optimizes your background apps, memory space, junk(cache) files and battery power, while keeping your device safe from virus and trojan.
Download this FREE optimization and security app that’s intuitively designed to protect your mobile lifestyle in just ONE tap.
Why 360 Security is a MUST-HAVE app?
★It’s the Strongest Booster-Is your phone running crazily slow? Let 360 Security’s renowned boost engine take care of it!
★It’s the Most Effective Cleaner-Lacking space for new photos or new apps ? Just clean application caches and junk files with one click!
★It’s a Smart Battery Saver- Battery draining fast? Adjust your draining settings and disable unnecessary apps that drain your battery!
★It’s the Best Security App -Worried about viruses or phishing? Don’t be! 360 Security’s top antivirus solution makes sure your device is free from malware, vulnerabilities, adware and Trojans!
Highlights of 360 Security - Antivirus:
►Security & Antivirus
Scan installed apps, memory card content, and new apps automatically. 360 Security’s latest protection technologies against viruses, adware, malware, trojan and more.
►Junk File Cleaner
Delete useless Android system files, large files and app caches for an instant speed boost to your Android performance, while freeing up storage space with a single tap.
►Memory Boost
Free up memory (RAM) and boost your mobile phone. Our One Tap Clean feature reclaims memory allowing you to open apps without delay!
►Power Saver
Intelligently saves your device’s power by knowing when to automatically trigger 360 Security’s Clean feature, which saves you all the battery power you need, when you need it the most.
►Anti-theft
An all-in-one anti-theft solution, should you lose your beloved phone. A suite of features including, Erase, Locate, Alarm and Lock can assist you with retrieving a lost device and protecting personal data.You can trigger remote features via our web interface at _http://findphone.360safe.com
►Privacy
Privacy & App Lock – Prevent data on the device such as apps, SMS, photo albums, and other important and private documents from falling into the wrong hands.
►Real time protection
Scan installed apps and local APK files in real time and also monitor each installation process. Naposledy upravil(a)
milann70 dne 10. 05. 2019 11:45, celkem upraveno 3 x.
31. 05. 2018 11:48
360 Security Free Antivirus,Booster,Space Clean v4.3.3.6973
4.0 a vyšší
Co je nového:1.Modifikovaná hra Boost - plynulost rychlost při hře.
2.Zlepšil Správce upozornění, aby se vám zabránilo nežádoucím upozorněním.
3. Opravena chyba.
https://www.ulozto.sk/!WLFYJiMZwztr/360-security-4-3-3-6973-apk
https://www.ulozto.net/!XqlIJw2tWFt8/360-security-4-3-3-6973-apk
milann70 dne 10. 05. 2019 11:46, celkem upraveno 2 x.
14. 08. 2018 20:36
360 Security Free Antivirus,Booster,Space Clean v4.5.5.3260
4.0 a vyšší
1.Supporting no ads in app.
2.Super lock screen ,to provide phone optimization tips and a variety of handy tools (super easy to use).
3.Space clean-up optimization, to solve the problem of lack of space and clean up more thoroughly.
4.Bug fixed and product performanced optimization.
5.More new features and optimization, welcome to experience.
https://douploads.com/ywevfefe8err
https://dropapk.com/th3qtapysrsc
https://dailyuploads.net/s2p3n7gumn1r
milann70 dne 10. 05. 2019 11:47, celkem upraveno 1 x.
06. 12. 2018 17:46
360 Security Free Antivirus,Booster,Space Clean v5.1.4.3833
4..1 a vyšší
1.Podpora žádných reklam v aplikaci.
2.Super lock obrazovka, poskytovat tipy pro optimalizaci telefonu a paletu praktických nástrojů (super snadné použití).
3.Space optimalizace optimalizace, vyřešit problém nedostatku místa a důkladnější vyčištění.
4.Bug pevná a produktová optimalizace.
5.Více nové funkce a optimalizace, uvítání zkušeností.
https://upload4earn.org/p69niqn8x0do
https://uploadocean.com/olytlin7aa7n
milann70 dne 10. 05. 2019 11:48, celkem upraveno 1 x.
25. 02. 2019 12:28
360 Security Free Antivirus,Booster,Space Clean v5.2.4.4060
4.1 a vyšší
https://upload4earn.org/703brua7nv1b
https://dropapk.com/n2sp10h4nyr6
07. 04. 2019 02:07
360 Security Free Antivirus,Booster,Space Clean v5.2.9.4242
4.1 a vyšší
1.Podpora žádné reklamy v aplikaci.
2.Super zámek obrazovky, poskytovat telefon optimalizace tipy a řadu užitečných nástrojů (super snadné použití).
3. Optimalizace prostorového vyčištění, vyřešení problému nedostatku místa a důkladnější vyčištění.
4.Bug pevnou a produktem optimalizovanou optimalizaci.
5.Více nových funkcí a optimalizace, vítejte na zkušenosti.
https://douploads.com/zeboj8kk9r6z
https://dropapk.com/844vqa4rlkbs
https://webshare.cz/file/4hA11I4l7E/360-security-5-2-9-4242-apk
milann70 dne 10. 05. 2019 11:49, celkem upraveno 1 x.
13. 04. 2019 16:27
360 Security Free Antivirus,Booster,Space Clean v5.3.0.4264
4.1 a vyšší
2.Super zamykání obrazovky, aby telefon optimalizace tipy a řadu užitečných nástrojů (super snadné použití).
https://douploads.com/1htpx4l898lm
https://dropapk.com/tmaijauq5xdv
https://webshare.cz/file/3jbQy1eb1Z/360-security-apk
10. 05. 2019 11:54
360 Security Free Antivirus,Booster,Space Clean v5.3.0.4265
4.1 a vyšší
https://uploadrar.com/7ph0vnjs74ew
https://douploads.com/3eopbhw9nuvz
https://dropapk.com/ra7s4c3e2whc
16. 12. 2019 12:45
360 Security Free Antivirus,Booster,Space Clean v5.4.3.4552
Požadavky: Android
4.1 a vyšší
2.Super zamykací obrazovka, která poskytuje tipy pro optimalizaci telefonu a řadu užitečných nástrojů (velmi snadné použití).
3.Space clean-up optimalizace, vyřešit problém nedostatku místa a vyčistit důkladněji.
4.Bug pevné a produktové optimalizace optimalizace.
https://uploadrar.com/t6thyxwpjpcl
https://uploads4u.net/kjcyxx6nhx8e
https://upload.ac/qzsrnz4awknz
