39 příspěvků
16. 07. 2017 21:13
Hibernator PRO: Hibernate running apps & save battery
Hibernator PRO: Hibernate running apps & save battery v1.1.2
Hibernator PRO: umožňuje spánek aplikací tím, že zavře všechny spuštěné aplikace a brání automatickému opětovnému spuštění aplikací. Je snadno použitelný a může šetřit data, baterii a výkon.
https://play.google.com/store/apps/details?id=com.tafayor.hibernator
Stahuj zde: PRO features unlocked
https://ulozto.cz/!7t2K3a8DCDoq/hibernator-pro-1-1-2-apk
https://webshare.cz/file/1jb7cb7pPS/hibernator-pro-1-1-2-apk
Hibernator lets you hibernate apps by closing all running apps and preventing the apps from relaunching automatically. It's easy to use and can save data, battery, and performance.
Your phone keeps many apps running in the background, which is consuming your system resources, and as a result draining your battery and reducing the available memory.
✓ Close all running apps
✓ Close background tasks and services
✓ Prevent the apps and services from restarting after being closed.
✓ Supports user apps and system apps.
✓ Notification quick access
✓ Widget
Task Killer
Hibernator is a very powerful Task Killer that kill tasks and processes and prevents them from restarting automatically.
Speed booster
Hibernator lets you speed up your phone when it runs slowly because of the many background running apps.
RAM CLEANER
Hibernator optimize you phone memory by freeing up RAM, and making space for new apps.
BATTERY SAVER
Closing apps helps save battery power and extend battery life.
CPU COOLER
Closing apps helps Cool down your phone temperature and reduces CPU usage.
PERMISSIONS
Accessibility Service permission : Hibernator requires the accessibility service permission in order to be able to close other apps.
03. 08. 2017 00:36
Re: Hibernator PRO: Hibernate running apps & save battery
Hibernator Pro: Hibernate running apps & save battery v1.1.5
+ Fixed bugs.
+ Updated the widget.
+ Added languages.
https://play.google.com/store/apps/details?id=com.tafayor.hibernator&hl=en
Stahuj zde: Pro features unlocked
https://ulozto.cz/!zF4x6UMCuxv5/hibernator-pro-v1-1-5-apk
https://webshare.cz/file/3jb1l855d2/hibernator-pro-v1-1-5-apk
18. 08. 2017 02:55
Hibernator Pro: Hibernate running apps & save battery v2.0.7
+ Přidán rychlý přístup k citlivým oprávněním používaným Hibernaterem s popisy a snadným přepínáním.
* Opraveny chyby.
https://ulozto.cz/!DsJH6rPxvZfr/hibernator-pro-v2-0-7-apk¨
https://webshare.cz/file/5rm7Jl5g57/hibernator-pro-v2-0-7-apk
23. 08. 2017 11:15
Hibernator Pro: Hibernate running apps & save battery v2.1.0
Přidána podpora automatického hibernace pro odemknutí odtlačku prstů a inteligentní zámek pomocí alternativního režimu vypnutí obrazovky.
Přidán rychlý přístup k citlivým oprávněním, které používá Hibernator s popisy a snadným přepínáním.
https://ulozto.cz/!UWJxLiKaMRrZ/hibernator-pro-v2-1-0-signed-apk
https://webshare.cz/file/2zp3Q23Nt2/hibernator-pro-v2-1-0-signed-apk
10. 09. 2017 19:12
Hibernator Pro: Hibernate running apps & save battery v2.2.1
Opraveny chyby.
Přidaný interval (zpoždění) mezi po sobě jdoucími akcemi automatické hibernace.
https://ulozto.cz/!vJkf89gwWv7Z/hibernator-pro-v2-2-1-apk
https://ulozto.sk/!MMyUXFLqFFvZ/hibernator-pro-v2-2-1-apk
22. 10. 2017 00:18
Hibernator : Hibernate running apps v2.2.5 [Pro]
* Opraveny chyby.
* Odstranění oprávnění správce zařízení.
Stahuj zde: Pro features Unlocked
https://www.ulozto.sk/!E1jIYlQLwaV4/hibernator-v2-2-5-pro-aosp-apk
https://webshare.cz/file/5k5jk2w33l/hibernator-v2-2-5-pro-aosp-apk
29. 04. 2018 14:47
Hibernator : Hibernate running apps v2.2.6 [Pro]
Přidána podpora pro systém Android Oreo.
https://uloz.to/!I36I7Xu28iy1/hibernator-hibernate-running-apps-save-battery-v2-2-6-pro-apk
https://ulozto.sk/!5ve8aoCVN8P0/hibernator-hibernate-running-apps-save-battery-v2-2-6-pro-apk
15. 05. 2018 14:18
Hibernator - Hibernate apps & Save battery v2.5.4 [Pro + AOSP]
v2.5.4: Opraveny chyby.
v2.5.0:
+ Zálohování a obnovení.
+ Chcete-li zálohovat nastavení, musíte povolit přístup k externímu úložišti.
* Opraveny chyby.
https://ulozto.sk/!Ty5heht1qWOB/hibernator-v2-5-4-pro-aosp-apk
https://ulozto.net/!eMWT8SBarYNL/hibernator-v2-5-4-pro-aosp-apk
11. 10. 2018 16:54
Hibernator Hibernate apps & Save battery v2.7.1 [Pro]
Co je nového: Opraveny chyby.
https://douploads.com/rhgb3ue63fea
https://uploadocean.com/ojt9bfzdjj69
https://webshare.cz/file/6t713A3j75/hibernator-hibernate-apps-and-save-battery-pro-2-7-1-apk
10. 12. 2018 17:25
Hibernator Hibernate apps & Save battery v2.7.2 [Pro]
Co je nového: Obrázek
oprava chyb
https://douploads.com/z535g0fgnvai
https://upload4earn.org/7t0g4io3mjuj
39 příspěvků
