21. 12. 2017 21:06
GPS Compass Navigator
GPS Compass Navigator v2.19 [Pro]
5.0 a vyšší
Popis: Když cestujete, pěší turistika anebo s předním náhonem jdete domů z pijatyky
:'D :'D :'D
https://play.google.com/store/apps/details?id=com.evo.gpscompassnavigator
https://www.ulozto.net/!6xkvTmAayN9S/gps-compass-navigator-pro-2-19-apk
https://webshare.cz/file/2xm7ij6nZ6/gps-compass-navigator-pro-2-19-apk
Functions:
- Compass
- Save current position or get coordinates from map
- Navigate to saved way point
- Voice navigation
- Track your path and save it to tracks list
- Follow saved path
- Backtrack
- Share your location
- Import/export GPX files
- Navigation on lock screen
- Show map (internet connection is required)
- Sunrise/sunset
- Open way point in external apps
- Show current location in Decimal, DMS, MGRS, what3words
- Show sun and moon position
- HUD (Head up display)
In navigator screen you have following info:
- Current address / current latitude and longitude
- Distance
- Speed
- ETA (Estimated time of arrival)
- GPS Accuracy
- Magnetic field strength
- GPS Altitude
- Traveled path visualization
- Trip computer
The app can work offline and even without magnetometer.
Supports imperial and metric systems, power saving mode, declination correction and coordinates in DMS.
Car mode to get correct bearing in vehicles when the magnetometer is not reliable.
Simple and user friendly interface, optimized to save phone battery.
You can use sun position to check compass calibration. Dotazy na SZ.
06. 02. 2019 13:18
GPS Compass Navigator v2.20.7 [Pro]
5.0 a vyšší
Co je nového: Rychlejší načítání, opravy chyb.
https://douploads.com/baxqsu2csb9i
https://upload4earn.org/egn8z65bqb3o
https://dropapk.com/3ywxovrvtkbk
https://speed4up.com/3f524nodfhwm.html
https://uploadbuzz.org/sjujc01c43b3
http://ul.to/rexkyaev
19. 02. 2019 16:01
GPS Compass Navigator v2.20.10 [Pro]
5.0 a vyšší
https://douploads.com/v3dt5zeowxct
https://upload4earn.org/9b80ov8pa2yg
https://dropapk.com/4m6yxzwsvpdg
https://speed4up.com/jvw7e2fqm9bc.html
http://ul.to/o76kvmu4
20. 02. 2019 13:27
GPS Compass Navigator v2.20.11 [Pro]
5.0 a vyšší
https://douploads.com/gdgnak49zcur
https://upload4earn.org/en6076bh0hoz
https://dropapk.com/a3h1d9xuu8q1
https://speed4up.com/9gywcl19wjwm.html
http://ul.to/zjd4zwx0
