Henry1
09. 09. 2009 07:54
08. 05. 2018 06:07
SD Card Test Pro
SD Card Test Pro v1.6.1 Patched
Requirements : ↑5.0x
Overview : Use the best SD card test tool! Test the speed of internal or external storage!
Easy to use even for beginners. Quick tests.
Highlighted features:
* Measure the speed of your external (removable) SD card
* Measure the speed of your internal storage
* Read/write tests, several different settings.
What's New :
v1.6.1
* Extended read-write test types with "all" (this will first run a write test then a read)
* Improved speed of data verification
Google Play :
https://play.google.com/store/apps/details?id=com.pzolee.sdcardtesterpro
Download :
https://uloz.to/!KpHOiXlD9nkf/sd-card-test-pro-v1-6-1-apk
https://upload4earn.org/czzmiif8s5zd
https://dailyuploads.net/jjzxakc3pckg
Henry1
09. 09. 2009 07:54
23. 09. 2018 18:04
SD Card Test Pro v1.6.3 Patched
What's New :
v1.6.3
* Enable run in background
Google Play :
Download :
https://uloz.to/!wWAwZa5RfFvt/sd-card-test-pro-v1-6-3-apk
https://upload4earn.org/bmtl8cfzpzqa
20. 12. 2018 00:35
SD Card Test Pro v1.6.7 [Patched]
5.0 a vyšší
Možnost přidání názvu SD karty.
Přidána klasifikace.
Drobné opravy chyb.
https://douploads.com/rwwtzfwpn6i8
https://upload4earn.org/u5j6hwtnm6w3
http://speed4up.com/b5e0oocnybe6.html
https://uploadbuzz.org/adpr5xnsorvt
http://ul.to/2m9x8m8g
https://uploadev.com/e4q2h3y911hh
Henry1
09. 09. 2009 07:54
15. 03. 2019 18:43
SD Card Test Pro v1.7.1 Patched
Requirements : ↑5.0
What's New :
v1.7.1
Added option to delete a single result from results tab
Fixed German translation
No LP or Google Play Modded needed.
More Info :
Download :
https://uloz.to/!kVEMNFkff3xR/sd-card-test-pro-v1-7-1-patched-apk
https://dropapk.com/pcoxswjk1nzq
01. 05. 2019 14:48
SD Card Test Pro v1.8.0 [Patched]
60,-Kč
5.0 a vyšší
Added auto-detection function for SD card
Save device name in result
Fixed several language translations
Moved "remove temporary files" button to a better position
Fixed report generation (export)
https://douploads.com/6xk7b3gnklp3
https://uploadrar.com/aqkdiyv2y3ju
http://ul.to/1i2d6tbw
https://speed4up.com/uu8dq4wl9obx.html
https://www.file-up.org/r79sfcb5dl22
https://dropapk.com/wq1nxuwiwwvv
Henry1
09. 09. 2009 07:54
29. 10. 2019 18:18
SD Card Test Pro v1.8.2 Build 62 Patched
Requirements : ↑5.0
What's New :
v1.8.2
Android 10 support
Maintenance fixes
More Info :
Download :
https://uloz.to/file/EfV5YZaNT8uR/sd-card-test-pro-v1-8-2-build-62-apk
https://dropapk.to/rvtij8e9wnv1
10. 01. 2020 19:55
SD Card Test Pro v1.8.3 [Patched]
60,-Kč
Požadavky: Android
5.0 a vyšší
Novinky ve verzi: Android 10 support.Maintenance fixes.
https://www.uploadship.com/6ccae3e62727cc9e
https://uploadrar.com/0tljlwlpopab
https://upload.ac/2q5yds8xc1s2
https://www.file-up.org/p6j2kljhzv6j
https://webshare.cz/#/file/6yK6bS4nz7/sd-card-test-pro-v1-8-3-4allmobile-cz-apk
22. 03. 2020 10:35
SD Card Test Pro v1.8.5 [Patched]
Požadavky: Android 5.0 a
vyšší
Novinky ve verzi: Pravidelná údržba a opravy chyb.
https://www.uploadship.com/50d54c8b4f99ba03
https://up-load.io/f6n5r2k447eh
https://www.file-up.org/wvk5uu2200yk
https://intoupload.net/gjhvxjv5q9ki
http://ul.to/t9nkgvty
https://uloz.to/file/f3jv0W0OH489/sd-card-test-pro-4allmobile-cz-apk
https://ulozto.sk/file/lD5CW3eyQJYp/sd-card-test-pro-4allmobile-cz-apk
https://ulozto.net/file/VZLq5JQFTpxy/sd-card-test-pro-4allmobile-cz-apk
https://webshare.cz/#/file/6ji3s528I4/sd-card-test-pro-4allmobile-cz-apk
