RAM cleanup
23. 05. 2018 14:00
RAM cleanup
RAM Cleanup v5.37 [Unlocked]
Výkonné vyčištění paměti. Stačí jen jeden start. Zvláštní znalosti a nastavení NENÍ zapotřebí!
ObrázekObrázek
https://play.google.com/store/apps/details?id=com.kosajun.easymemorycleaner
Stahuj zde: *Paid features unlocked!
https://uloz.to/!f8vVntnniIY9/ram-cleanup-5-37-apk
https://www.ulozto.sk/!Euzno68vd7Ph/ram-cleanup-5-37-apk
Clean up (free up) the memory (RAM) to speed up (boost) your device with saving more battery and cooling down CPU. Just starting the app makes it easy to totally optimize your device.
You don't need any special knowledge for optimization of the smartphone system and performance.
You can remove the animation if you want.
Total memory reduction helps much faster operation with saving battery for gaming, browsing and OS itself.
Advanced functions:
-Auto closing.
-Auto clean function by recognition of exceeding threshold of memory usage ratio.
-Color settings for texts, background, foreground, and animation.
-Shortcut for customized cleanup.
