Screen:MAX AppLock - Your privacy protection. Guard privacy 24 hours a day! Lock your apps with app password lock, pattern lock, photo vault. Supports applock must-haves: App Locks, Intruder Selfie & Lock Disguise. Protect your privacy and photo safe in all possible ways.
https://play.google.com/store/apps/details?id=com.apps.security.master.antivirus.applock
https://dropapk.com/7m2e180a93py
https://upload4earn.org/e4t87ytlksda
http://cloudyfiles.org/m3lzoouyn9td
http://suprafiles.me/rxtwfyhmilvw
https://uploadocean.com/5ebq9n13tslq
https://ulozto.sk/!SkKOXjKgc0RH/max-app-locker-pro-1-2-8-apk
MAX AppLocker - the application lock and lockscreen - gives privacy protection for your android phone. Various locks are provided, such as whatsapp lock and notification lock, which makes application lock a must-have privacy guard. Download Max, enjoy app lock free!
Feature list
App Locks - Both app password lock, pattern & fingerprint lock supported
Intruder Selfie - Prevent intruders who try to unlock your apps
Photo Vault Free - Photo vault with lock to hide pictures and videos.
Lock Cover - Fake the unlock screen into an error report
Lockscreen - Protect your privacy from intruders with app password lock and pattern password
Notification Organizer - Hide unwanted notifications. Never miss any important messages
App Manager - Uninstall useless applications & remove apk files
App Lock widget - One tap to enable/disable locks
Parental Control - Lock important apps to avoid child messing it up
Cleaner & speed boost - Clean junk files, apk files and boost phone speed
Battery Saver - Save battery power for Android
