Requirements : ↑4.1
Overview PRO Diagnostics, Programming and Monitoring for all Audi, Volkswagen, Seat and Škoda vehicles.
BASIC App Features :
- Automatic vehicle identification from VIN (Vehicle identification number)
- Automatic all systems scanning and analyzing
- Read and clear diagnostic trouble codes from all control units that is installed in your car (i.e. Engine, Transmission, ABS, Airbag, Multimedia, Air conditioning, etc.)
- Read information about control unit (i.e. Part number, Software number, Coding, etc.)
- Multi language database
- Diagnostic data log sharing via email
- Car battery analyzer
- Connected cars history
- Information about car
- Gauges
- Device Alert
- Engine, Equipment and Fault code lookup
- DIY manuals
PRO App Features :
- Trouble code Freeze frame
- Advanced control unit information
- Live data, measurements
- Textual Long coding, Adaptations, Live data, Basic settings, Output test for UDS control units
- Charts
- Coding
- Coding II
- Long coding
- Sub control units information
- Sub control units coding
- Getaway installation list coding
- Adaptation
- Long Adaptation
- Basic settings
- Output test
- Security access
- Login finder
- Readiness (UDS)
- Control unit reset (UDS)
- Diagnostic service change
- Control unit Backup
- Control unit programming history
- Car programming history
NEW
- Coding, Adaptations, Live data, Basic settings Labels Developer (Now only for Beta testers)
APPS (one click functions)
Activate or deactivate car functions in just one click. More than 500 different apps are available for various vehicles to fast and easily control comfort, lightning and other settings. Apps may depend on the vehicle equipment. Apps use additional in app credits.
SUPPORTED MODELS :
All VAG ( Audi | VW | Seat | Škoda ) models are supported! Some models until 1996 years need VAG 2X2 adapter.
Volkswagen :
UP | Polo | Golf | Golf Plus | Golf Sportsvan | Beetle | Bora | Corrado | Scirocco | Jetta | Vento | Touran | Tiguan | Eos | Fox | Lupo | Passat | Passat CC | Sharan | Touareg | Phaeton | Caddy | Multivan | Transporter | Multivan | Vento | Amarok | XL1 | Arteon
Audi :
80 | 90 | 100 | 200 | A1 | S1 | A2 | A3 | S3 | RS3 | A4 | S4 | RS4 | A5 | S5 | RS5 | A6 | S6 | RS6 | A7 | S7 | RS7 | A8 | S8 | Q2 | SQ2 | Q3 | SQ3 | RS Q3 | Q5 | SQ5 | Q7 | SQ7 | TT | TTS | TT RS | R8 | R8 Spyder | Coupe | Cabriolet
Škoda :
Citigo | Fabia | Felicia | Roomster | Rapid | Octavia | Yeti | Superb | Praktik | Kodiaq
Seat :
Mii | Ibiza | Toledo | Leon | Altea | Alhambra | Arosa | Cordoba | Exeo | Inca | Ateca
OBDeleven DEVICE :
Unique Bluetooth device, which allows you to do full car systems diagnostics, programming and monitoring. The device connects to OBD-II diagnostic socket. This tool works only with OBDeleven application for Android.
IMPORTANT :
This application doesn't work with ELM327 and other OBD-II devices! It requires unique OBDeleven device.
The system is using online databases so it requires a good internet connection for fast and smooth work!
What's New :
v0.9.4
New features:
- Manuals builder (Can create own manuals)
- Wallet (View credit transactions history)
- Account management (now can change email, password and link accounts)
PRO features unlocked | Login Required
More Info :
https://play.google.com/store/apps/details?id=com.voltasit.obdeleven
https://uloz.to/!wB9aKFwlXSAN/obdeleven-pro-v0-9-4-apk
https://upload4earn.org/flv9rjgtf72l
