5 příspěvků •Stránka 1 z 1
Alarm Clock for Heavy Sleepers
23. 09. 2018 07:36
Alarm Clock for Heavy Sleepers v3.3.0 [Premium]
Popis: Android inteligentní budík je inovativní, bohatý na funkce budík. Je to šikovný a plně přizpůsobitelný a může udělat ranní rutinu lépe; žádné další přehánění!
https://play.google.com/store/apps/details?id=com.amdroidalarmclock.amdroid
https://uploadocean.com/eukn4kmz2rg4
https://upload4earn.org/jqn95x6pvihs
https://douploads.com/n2iovnw7r2kb
http://ul.to/4yvp8o4b
• An alarm clock with unlimited, fully customizable alarm profiles
Recurring alarms - on top of the basic settings, you can use advanced recurrence, such as daily or weekly repeats, intervals, set expiration, etc. (ideal for shift workers working in cycles)
One-time alarms - set any date
Countdown alarms - perfect for an afternoon siesta or zizz
• Each alarm has its own settings
Wake up and start your morning routine with your favorite song along with real-time weather information
Use challenges (Math, Captcha, Wi-Fi, NFC) to prevent oversleeping - great for heavy sleepers
Adjust snooze time on the fly - for the snoozy ones
Restrict alarms to locations
Many more features to tweak your alarms, yet you can familiarize yourself with it in a timely manner
• Let you sleep on off-days
Ever been roused from a good, deep sleep on a public holiday, just because the alarm clock wasn't turned off? AMdroid knows the public holidays for your country; alarms won’t go off on these days (optional).
• Android Wear integration
Snooze or dismiss alarms right from your wrist. Adjust next alarm or add new one-time alarms, using voice commands.
• No more oversleep with this alarm clock
Can't wake up? Configure dismiss challenges to wake up timely. Use post alarm confirmation to make sure you are awake and avoid oversleeping. Perfect alarm clock for heavy sleepers.
• Wake up during light sleep
Awakening from a good, deep sleep can cause enervation. Configure a gentle pre-alarm that will go off before the main one. By utilizing sleep cycle calculation following your biorhythm it can be scheduled automatically according to your sleep patterns. Lower the volume and disable vibrating for this pre-alarm, so it'll only wake you if you are in light sleep for a better morning routine start. This can help defend against sleepiness and lethargy in the mornings. Wake up easily; be energetic and zestful!
• Sleep mode
To avoid oversleep you need to go to bed timely. AMdroid will let you know with a bedtime (sleep advise) notification if it's time to fall asleep in order to wake up fresh and have a better morning routine. When sleep mode is activated sleep cycle calculation can be started to follow your sleep patterns and have an easier awakening in the morning. With Stats, you can also track how much time you spend sleeping.
• Places
Make your alarm clock location-aware, so your alarms will only go off if you are in a certain area. Heading out for a business trip or just sleep over somewhere else for the night? Your morning routine will probably change, so AMdroid will temporarily disable your regular alarm profile automatically.
• Stats
Ever wondered how much time you spend snoozing? AMdroid Smart Alarm Clock will show you statistics, you can analyze and use to fine-tune your alarm settings.
• Nothing better than an afternoon siesta
Tiredness overcame and feel drowsy? If you are sleepy or half asleep, use the countdown alarm function as a timer for your afternoon doze. Set the timer, and the alarm will go off if it has elapsed, and you won't oversleep. Awaken energized and lively.
23. 05. 2019 08:40
Re: Alarm Clock for Heavy Sleepers
Alarm Clock for Heavy Sleepers v4.0.0 [Premium Mod]
Co je nového: Obrázek
NEW: Custom Theme coloring (Android 5.0+)
- You can set the theme primary and accent colors, making it possible to have 100s of different combinations
NEW: Brand new theme: Night Black
NEW: Improved alarm list
- More alarms can be visible at the same time
- Dedicated on/off switch for each alarm
- Tap on the Note of the alarm to edit it directly (same as with the Time of the alarm)
- Swipe away alarms for quick deletion
- History is moved to a dedicated screen accessible from the left main menu
- Snoozed alarms are shown at the top
NEW: Dense View:
- An optional alarm list layout that shows much more alarms compared to the default one.
NEW: Filter options for the alarm list
- Filter the alarm list based on the alarm status, recurrence type and profiles
NEW: Sort order options for the alarm list
- Sort the alarm list based on next occurrence, time, note, profile name or usage
NEW: New and improved widgets
- Widget with buttons asks for confirmation when clicking on any of the actions (e.g. skip or +/-)
- New simple widget to start the Night Clock
- New analog clock widget
- New digital clock widget that shows the time and the next alarm information
NEW: Snooze and Dismiss challenges are separated and can be configured individually
NEW: Backup challenge difficulty and count can be set separately from the main challenge
NEW: Sensors moved to Profile Settings and there is a new 'Flip' sensor
NEW: Alarm screen appearance options moved to Profile Settings
NEW: Night clock shows more information (next alarm, charging state and date)
FIX: Scheduling issue with 'On offdays' recurrence when multi day off-day was used
FIX: Vibrate issue when delay and challenge pause interval both were used and triggered
FIX: Importing calendar events where all day was enabled and the event spanned over multiple days
FIX: Restoring backups on Android P that were made on earlier Android versions
https://www.file-upload.com/cpaw6isdf8am
https://upload4earn.org/yyt4xppvg68n
https://uploadev.org/v2m0ofhog3te
https://douploads.com/2igpus120w2n
https://uploadbuzz.org/a1253fv9odkj
http://ul.to/dhcavkw8
21. 08. 2019 11:34
Alarm Clock for Heavy Sleepers v4.2.0 build 168 [Premium Mod]
NOVINKA: převod textu na řeč: vaše alarmy nyní mohou mluvit! Nakonfigurujte text v Nastavení profilu, který se bude periodicky číst nahlas, když se alarm vypne.
NOVINKA: Noční hodiny lze nyní nastavit v nastavení zařízení jako spořič obrazovky (daydream) (Android 4.2+)
Oprava: Úprava času příštího výskytu je nyní resetována, pokud je další výskyt přeskočen (nebo je přeskočení odstraněno)
Opravy drobných chyb a vylepšení.
Stahuj zde: Premium features unlocked
https://dropapk.to/5rd8jr6yxt5k
https://upload4earn.org/s0y72bbfsx4j
https://douploads.net/8fjj5ocuyi4l
https://speed4up.com/bsnu0fj00rh0.html
http://ul.to/rn9j3q3f
Henry1
09. 09. 2009 07:54
26. 10. 2019 10:46
Alarm Clock for Heavy Sleepers v4.5.2 Build 198 Premium
Requirements : ↑5.0
What's New :
v4.5.2
NEW: Support to have multiple calendar alarms for the same calendar event
FIX: Hourly recurrence scheduling issues under certain circumstances
FIX: Reboot protection issues on some devices
FIX: Next alarm notification wasn't always showing up when the delay was enabled
Minor bug fixes and improvements
Premium features unlocked;
Ads Removed;
Disabled / Removed unwanted Permissions + Receivers and Services;
Analytics / Crashlytics disabled;
Maps Location work;
Send anonymous stats disabled by default.
More Info :
https://play.google.com/store/apps/details?id=com.amdroidalarmclock.amdroid&hl=en
Download :
https://uloz.to/file/g5nAc7GKX2Ps/alarm-clock-for-heavy-sleepers-v4-5-2-premium-apk
https://dropapk.to/fi2xn3baqdnn
08. 01. 2020 21:34
Alarm Clock for Heavy Sleepers v4.6.0 [Premium] [Mod]
NEW: Bulk skip and skip remove options
NEW: Option to mute alarms automatically when phone is set to silent or vibrate-only
NEW: Night clock orientation can be fixed
FIX: Fixed an issue with dynamic intervals for calendar integration
FIX: Improved Reboot Protection on newer Xiaomi devices
FIX: Fixed an issue accessing profile settings when WiFi challenge was set to both snooze and dismiss
FIX: Fixed an issue scheduling alarms for the last day with On Off days alarms when multi-day off day was used
https://www.uploadship.com/75546d588bdf7628
https://mixloads.com/tzfwmznyhlk9
https://dropapk.to/l3pgdpzgxhm6
https://webshare.cz/#/file/77u6O64p94/alarm-clock-for-heavy-4allmobile-cz-apk
