Image Resizer Premium
12. 10. 2018 19:20
Image Resizer Premium v1.30
Image Resizer quickly reduces your pictures sizes to few kb . It can change image resolution to any selected custom resolution .
https://play.google.com/store/apps/details?id=apps.sai.com.imageresizer.demo
Stahuj zde: Premium features unlocked
https://dailyuploads.net/nz7lu56kdfhu
https://upload4earn.org/0bgpt8au19vc
https://douploads.com/b0y94d5h8kzj
Edit images and share on e-mails, Instagram, Facebook, whatsapp ,web forms, etc. Share your pictures much faster with your friends and family.
For single or multiple images Image Resizer is a perfect choice.
Images are easily reduces in size or resolution without losing quality using image resizer. Save the images if you like from the menu. Image resizer saves images in separate folder. You can view resized images from gallery or withing app.
You can upscale or downscale any image using custom resolutions. Image Resizer is a free application designed to help you resize images in batches. Image Resizer performs simple resizing of the images in a fast and easy-to-use way. Image resizer maintains the picture aspect ratio by providing a resolution list. Resize images before sharing or posting them on Facebook, ,Gmail , Instagram , Twitter, Pinterest, Reddit, Tumblr, Google+ etc.
You can preview an image after any operation of resizing or compression , discard it if you don't like, save it or share it if you like the resizing.
It has intuitive design and easy to use features for image resizing and comparing , the developers are most welcome for suggestion for improvement.
How it works:
1) Select single picture or multiple pictures from gallery .
2) Image resizer displays the selected images(s).
3) Select the resolution (width x height) from the list, or enter percentage of orignal .
4) No need to lock the aspect ratio if you don't need to.
4) The selected picture or images get reduced and displayed .
5) Click on any processed image to see the comparison of older and new pictures.
6) You can cancel an operation
7) If you don't like the result of processed images , just press reset , all original images are reset.
14. 10. 2018 17:27
Re: Image Resizer Premium
Image Resizer Premium v1.33
Co je nového: Oprava chyb.
https://dailyuploads.net/t15zybck1irg
https://upload4earn.org/bttnar9qypv5
https://uploadocean.com/0709w42fysmb
13. 11. 2018 14:32
Image Resizer:Crop and Compress Photo & Picture PRO v3.0
https://play.google.com/store/apps/details?id=com.image.resizer.photo.shrinker
Stahuj zde: PRO features unlocked
https://dailyuploads.net/3uvs0oo0hmdq
https://upload4earn.org/1f8rnwbjp5oa
https://uploadocean.com/wwo1gzm5m856
