WiFi Speed Test Pro
04. 11. 2018 13:29
WiFi Speed Test Pro
WiFi Speed Test Pro v3.0.0 [Paid]
(60,- Kč)
Pozadavky: Android 4.4 a vyšší
Popis: Wifi Speed Test app is a wifi speed and local network (LAN) speed meter. The best speed test for your Ethernet network!
Obrázek Obrázek Obrázek Obrázek Obrázek
Fixed disappearing tabs in special cases
Fixed some rare crashes
Added Android 9.0 (Pie) compatibility
https://play.google.com/store/apps/details?id=com.pzolee.android.localwifispeedtesterpro
https://srfiles.com/nw15k1h2e4zx
https://dailyuploads.net/udpvydsii8cm
https://upload4earn.org/kwd5fmt7k59t
http://clfiles.com/fm13z4sezcpo
https://douploads.com/dz1w5szi7fzt
Pro features:
✓ Ad free
✓ iperf support
✓ You can enable zoom in/out in the graph (visualization)
✓ You can change the default time frame in the graph to see more data
Main Features:
✓ Test the speed of wireless and wired networks
✓ Test the Download and Upload Speed
✓ Save the past results of Wifi speed test automatically, including download and upload speed, ping, signal strength, network name, IP address
✓ Display IP address, network information, latency, signal strength, channel information
✓ Easy sharing of speed test results
✓ Test Windows share (SMB, Samba) speed
✓ Test the speed of FTP server
✓ Test can be done via TCP or UDP
✓ Tethering and hotspot support
✓ Easy sharing of test results
IMPORTANT for Android 6 (Marshmallow): Please enable location service (Settings>Location) or the app won't work properly. This is not required for the app, this is a problem in android 6.0 (without it the app won't see the networks).
This app will not be useful unless you have a second phone or computer to use it as server!
You can download the server application (wifi_speed_test.exe/py) to your computer from here: https://bitbucket.org/pzolee/tcpserver/downloads
Important: This is not an Internet speed test app!
This application will measure the speed of your local network,
live Internet connection is not required.
kiklop64
Samsung Galaxy A52s 5G
31. 12. 2011 09:26
08. 11. 2018 02:51
Re: WiFi Speed Test Pro
nefunguje píše že to nemá licenci
23. 02. 2020 14:54
WiFi Speed Test Pro v4.1.0 [Paid]
Požadavky: Android 6.0 a vyšší
Novinky ve verzi: Opravy údržby.
https://userupload.net/ux7xewkm7nvc
https://up-load.io/qpocwdt4z1fe
http://ul.to/rrv4b14l
https://mixloads.com/mt2dhi9jt5gp
https://www.uploadship.com/197de5f9aa7aad71
https://webshare.cz/#/file/1xtDi5F65w/wifi-speed-test-pro-4-1-0-apk
