20. 02. 2019 17:16
Network Speed - Monitoring - Speed Meter
Network Speed Monitoring Speed Meter v2.0.6 [Pro]
4.1 a vyšší
Popis: Network Speed a small, fast and free network tool. You can monitor your network speed in real time and show accurate info instantly in the background.
https://play.google.com/store/apps/details?id=com.evozi.network
Stahuj zde: Image Pro features unlocked
https://www52.zippyshare.com/v/ZYlU2Ff4/file.html
https://www.mediafire.com/file/6vyd2xp642c44xh/
Ever wonder why your webpage is loading slowly or looking for internet speed meter for monitoring? Now you can check your network speed with ongoing notification or floating widget for real time statistics at a glance.
Network Speed - Highlights
★ Real-time speed update
★ App usage statistics
★ Network connections monitor (netstat)
★ Lots of customization options
★ Battery & RAM efficient
★ Detailed daily data usage statistics
★ Download & upload speed graph
★ Daily traffic usage in notification
★ Monitors your traffic data for the last 30 days
★ Show ping result on floating widget
★ Accurate data usage monitoring
★ Data usage alert
★ Compatible with all types of network (3G ,4G & LTE, WiFi, VPN)
and more! Download now and experience it yourself
Ability to display at:
- Notification bar
- Floating widget
- Quick settings Dotazy na SZ.
Henry1
09. 09. 2009 07:54
15. 05. 2019 08:32
Network Speed - Monitoring - Speed Meter v2.0.6 Build 57 PRO
Requirements : ↑4.1
What's New :
v2.0.6
[Added] Show on connect for floating widget
[Improvement] Floating view widget (better alignment) & minimal notification
[Fixed] Floating hide full screen sometimes not working
[Fixed] Bugs
More Info :
Download :
https://uloz.to/!RApxNt6zgsiA/network-speed-monitoring-speed-meter-v2-0-6-build-57-pro-apk
https://dropapk.com/dz6iqs20wx94
