20,-Kč
Požadavky: Android: 4.2 a vyšší
Popis: Pimp obrazovku s kulatými okraji obrazovky je primární účel aplikace. Kulaté rohy lze zaokrouhlit u vašeho displeje bez ohledu na zařízení, které používáte.
https://play.google.com/store/apps/details?id=com.bhanu.roundcorner
https://douploads.com/t2gscpscy8kk
https://upload4earn.org/i3kohju0ujwd
https://speed4up.com/msznwbtr9yf7.html
https://www.file-up.org/t88dik9v8089
https://uploadbuzz.org/urzc67m2fnt2
http://ul.to/m9xj2k6x
https://uploadev.com/jd2dhv9bqm92
Round up the squared corners with 40 superimpose curvy designs for your screens 4 corners.(allows specifying which corners to enable or disable)
Round Corners doesn’t require root and works on all devices running Android 4.0 Ice Cream Sandwich and newer iterations of Google’s operating system
Furthermore, the Round Corners even allows you to set specific looks for individual apps so you can opt to minimize or even turn off its effect entirely when launching certain apps, and highlight it when using others.
Naturally, it’s fair to say that Round Corners produces the best effect with round edges of screen for all apps on devices.
The Round Corners is lightweight app and shouldn’t leave a significant battery footprint. In fact, you may even save some battery life if you use Round Corners on a device with an AMOLED display panel that doesn’t light up black pixels, though any potential savings probably won’t be large enough for you to notice a difference in everyday use.
Permissions
• No internet access require.
• System overlay - used for draw over apps
• Accessibility Service - used for app specific settings for 4 corners.
