Timestamp Camera Pro [Paid]
14. 03. 2019 13:14
Timestamp Camera Pro v1.100 [Paid]
140,-Kč
Požadavky: Android: 4.3 a vyšší
Popis: Časové razítko Fotoaparát je nejlepší aplikace přidat časová razítka na nová videa.
https://play.google.com/store/apps/details?id=com.jeyluta.timestampcamera
https://upload4earn.org/xf7q1i9id9jw
https://dailyuploads.net/mqb9vswp4jmp
https://douploads.com/jgfqbrpm763a
● Add current time and location when recording or capturing, you can change time format or select the location around easily. Timestamp Camera is maybe the only App that can record video with the time accurate to second.
- Support 20 timestamp format
- Support change font, font color, font size
- Support set timestamp in 6 positions: top left, top center, top right, bottom left, bottom center, bottom right
- Support auto add location.
● Support display custom text on camera. For example, you can input "Good day at the zoo"
● All of the film, time effects are real-time and can be used when record or capture.
● Can change effect, toggle camera when recording
● Support portrait and landscape
● Support change resolution
● Photo and Video will be saved to Camera roll
08. 04. 2019 04:31
Re: Timestamp Camera Pro [Paid]
Timestamp Camera Pro v1.105 [Paid]
140,-Kč
Co je nového: Obrázek
Oprava "selhání při nahrávání videa na Pixel3"
https://dropapk.com/e7unlesg7el4
https://douploads.com/tdya6lzm6ym5
24. 07. 2020 14:17
Timestamp Camera Pro v1.175 [Paid]
Oprava „Fotografie pořízené v režimu videa byly někdy zcela černé“
https://userupload.net/2wir30wcudmw
http://ul.to/faojszt0
https://webshare.cz/#/file/36GanxjdYT/timestamp-camera-4allmobile-eu-apk
