31. 03. 2019 13:17
Astrolapp Live Planets and Sky Map
Astrolapp Live Planets and Sky Map v4.0.0.1 [Paid]
55,-Kč
4.2 a vyšší
Popis: Astrolapp ukazuje cesty objektů sluneční soustavy na obloze, včetně drah Slunce, Měsíce a planet, ve stylu středověkého astrolábu.
https://play.google.com/store/apps/details?id=com.mkreidl.astrolapp
https://upload.ac/g7t1o0xmmxpd
https://upload4earn.org/b99s17yo4g3t
https://douploads.com/ruyiw4wtrfht
https://dropapk.com/gyhctoolr3hi
https://speed4up.com/na3phkx305r6.html
http://ul.to/y3bnwc31
In addition to the Solar System, Astrolapp's sky map shows 9096 of the brightest stars and the 48 Ptolemaic constellations. Use Astrolapp as a planning tool for your next astronomical observation trip or as a companion for evening star-gazing: It offers a colorful daytime mode as well as a darker red-light mode for comfortable use with the night sky!
What makes Astrolapp's representation of the night sky different from other star-gazing apps? Astrolapp not only helps to locate stars and planets as they can be seen from Earth at any date and location, but visualizes the motions and the mechanics of the sky through a planispheric representation of the celestial sphere:
From the surface of the Earth we perceive the sky as a sphere (the celestial sphere) around us. The upper halfsphere is the visible part of the sky above our horizon, while the lower one is 'covered' by the earth. The stars and the bodies within the Solar System appear to move on that sphere.
Astrolapp displays the celestial sphere in the exact same way as someone sitting on the north (resp. south) pole of this sphere could view it. From this point of view the Sun appears to move along a circle parallel to the celestial equator in the course of a day like on a 24-hours-clock. The other stars and planets appear to move somewhat more or less than 360 degrees per day, depending on proper motions of the objects within the Solar System.
* Planisphere showing the positions and motions of the Sun, the Moon and the planets
* Display of the 9096 brightest stars and the 48 Ptolemaic constellations
* Moon phase and phases of the planets; Retrogradicity of planets
* Precise numerical position data for stars and the Solar System's objects in an ecliptical, equatorial or horizontal coordinate system; either heliocentric, geocentric or topocentric
* Real time mode or manual mode, the latter allowing to "scroll the sky" into arbitrary centuries
* Automatic detection or manual selection (optionally via a map) of the observer's geographic location. Save locations to permanent memory.
* Graphical display of the ecliptic and the positions of the zodiac signs
* Optional height and azimut lines
* Calculation of local solar time and local and Greenwich sidereal time
* Zoom into the graphical display, i.e. to observe transit events in real time, or in history or future
* Night mode (monochrome black/red)
* Projection with center in the north or south pole of the celestial sphere, depending on the position of the observer Dotazy na SZ.
10. 04. 2019 11:39
Astrolapp Live Planets and Sky Map v4.1.0.5 [Paid]
50,-Kč
4.2 a vyšší
Číselná indikace směru v ručním režimu je pevně nastavena.
https://uploadrar.com/e93wil2axehy
http://ul.to/brd1b61x
https://speed4up.com/k12pxuf8iwm7.html
https://www.file-up.org/ovoei9tfv83g
https://dropapk.com/65iimd34cnga
https://douploads.com/xmyysx6ct31d
15. 12. 2019 02:18
Astrolapp Live Planets and Sky Map v5.0.0.6-installed [Patched]
Požadavky: Android 4.2 a vyšší
★ Home screen widget
★ Display Messier objects
★ Performance optimizations
★ Fixed ecliptical longitudes for objects in Libra
★ Ported to Android 29
★ Translation to Japanese
Mod Info:
No LP or Google Play Modded needed.
Více info:Kód: Vybrat vše
Stahuj zde:Kód: Vybrat vše
https://mixloads.com/40kvg0a1iy03
https://uploadrar.com/303vcqkg1lqw
https://www.uploadship.com/f0e281a79158635a
17. 01. 2020 22:22
Astrolapp Live Planets and Sky Map v5.1.0.0-installed [Patched]
Požadavky: Android
4.2 a vyšší
Novinky ve verzi: Funkce hledání objektů Messier.
https://www.uploadship.com/3fd552dc4ecaeabc
https://up-load.io/g5p19asxosdi
https://upload.ac/zr5wk700e49e
http://ul.to/jhd3afyo
https://webshare.cz/#/file/3q62oE2kj5/astrolapp-v5-1-0-0-mod-apk
