Speed View GPS Pro
18. 04. 2019 08:22
Speed View GPS Pro
Speed View GPS Pro v1.4.19 [Patched]
(22,- Kč)
Pozadavky: Android4.0 a vyšší
Popis: Speed View GPS can track your speed,distance,time,location and also can get start time,time elapsed,avg speed,max speed,altitude...
Connect to Google Drive.
Export GPX to Excel.
Floating Speed:Allow Speedometer to display speed over map apps.
What feature needs the Camera permission?
Now you can view your track on your web browser, upload gpx file just by scanning QRcode.
Mod Info:
No LP or Google Play Modded needed.
Maps Location works;
Disabled / Removed unwanted Permissions + Receivers and Services;
Analytics / Crashlytics disabled.
https://play.google.com/store/apps/details?id=luo.speedviewgpspro
https://webshare.cz/file/Kb6qr2165T/speed-view-gps-pro-v1-4-19-patched-apk
https://douploads.com/0w57lg6smzij
https://uploadrar.com/qjzhurf2pkiz
http://ul.to/op28qv28
https://speed4up.com/5r448kdmof76.html
https://www.file-up.org/vg4hqniq1zha
https://dropapk.com/7goifjd5v4ah
Features included
- Save your track info.
- Switch between car speedometer and bike cyclometer.
- mph,knot and km/h mode.
- Map integration,get your location.
- 16 color styles.
18. 04. 2019 20:24
Re: Speed View GPS Pro
Speed View GPS Pro v1.4.20 [Patched]
22,-Kč
Připojte se k Disku Google.
Export GPX do Excelu.
Rychlost plovoucí rychlosti : Umožněte rychlosti otáčení zobrazovat na mapových aplikacích.
Jaká funkce vyžaduje oprávnění fotoaparátu?
Nyní si můžete prohlédnout svou stopu ve webovém prohlížeči, nahrát soubor gpx právě skenováním QRcode.
https://douploads.com/2ccw539rsc9z
https://dropapk.com/a6stawu33r58
https://www.file-up.org/zfsymgcwjy7u
https://speed4up.com/xsdppkc8xg0e.html
http://ul.to/yjw1obv0
https://uploadrar.com/77sppj7ixj7h
11. 07. 2019 20:43
Speed View GPS Pro v1.4.23 [Patched]
Mod Info:
https://www.uploadship.com/f35629fd1cd2abcd
https://uploads4u.net/v4l2ouieqrf7
https://uploadrar.com/z1teiyrsxnky
http://ul.to/sivqfe02
https://upload.ac/08s8ci9miqdk
