4 příspěvky •Stránka 1 z 1
Weather Forecast 2019 VIP
23. 08. 2019 01:30
Weather Forecast 2019 VIP v2.1
170,-Kč
Požadavky: Android 4.4 a vyšší
Popis: Upozornění na počasí z předpovědi počasí 2019 jsou vynikající z hlediska jejich přesnosti. Ať už je vítr, slunce nebo déšť, můžete o krok dopředu s předpovědí počasí radarem.
https://play.google.com/store/apps/details?id=com.mobiledev.realtime.radar.weather.forecast.pro&hl=en
https://upload.ac/qgfvc118vzio
https://uploadrar.com/ve6smk74huyz
https://www.uploadship.com/079505377996ab4d
Weather alerts from Weather Forecast 2019 are superior in terms of their accuracy. Whether wind, sun or rain, you can go one step ahead with the weather radar Weather Forecast. Be prepared for daily forecasts or sudden weather changes with live alerts and accurate weather forecasts. Daily weather photos provide storm warnings, weather updates.
Here are the reasons you should use Weather Forecast 2019:
1. Forecast the exact weather whenever and wherever you need them. Weather Forecast of Weather Forecast does not disappoint you
2. Serious weather alerts help you be safe
- Be prepared for every extreme weather event on the horizon with real-time weather alerts and storm warnings.
3. Today's weather temperature
- RealFeel technology tells you the difference between what the weather looks like and how it really feels.
4. Update weather wherever you are
- Get local forecasts when you are at home or update the weather around the world when you go away.
5. Weather live 24/7
- Check in advance up to 15 days or check our weather radar to know the exact weather forecast every minute!
6. And this is a beautifully designed application. Do you believe it? Try it and know it
- Manually search for location by name or zip code.
- Current weather condition.
- Hourly weather forecast.
- Locate by network and GPS (Global Positioning System).
- 15-day weather forecast.
- Radar Service
- Celsius and Fahrenheit temperature unit.
- Relative humidity percentage.
- Atmospheric pressure.
- Visibility distance.
- Precipitation.
- Follow weather and forecast for multiple locations.
- UV-Index.
- Dew point.
- Weather notification alerts.
- Wind speed and direction with different units.
- Sunrise and Sunset times.
- Display temperature in status bar (Notification bar).
- Multiple weather providers.
- Share weather and location information with friends.
- Next alarm and current battery level display.
- Automatic location detection
- Customize font for clock and date.
- Moon phase.
- Update on WiFi only and stop while roaming.
- Temperature.
- Elegant home screen widgets.
- Automatic update intervals.
- Weather map.
20. 09. 2019 06:47
Re: Weather Forecast 2019 VIP
Weather Forecast 2019 VIP v2.2
170,-Kč
Podpora více jazyků.Přidat sdílený vlastní obrázek počasí.
https://www.uploadship.com/4bd3a6d397520055
https://uploadrar.com/l1cy935bojjk
https://dropapk.to/s23cfgk8aecb
22. 01. 2020 02:59
Weather Forecast 2019 VIP v2.20.01.20
Novinky ve verzi: Podpora více jazyků.Přidat sdílený vlastní obrázek počasí.
Více info: Stahuj zde:
https://www.uploadship.com/fbf4c64e43df61bd
http://ul.to/2ohvipx7
https://upload.ac/0azeqn0wqf2o
https://webshare.cz/#/file/22k4076792/weather-forecast-2-20-01-20-apk
17. 06. 2020 12:29
Weather Forecast 2019 VIP v2.20.03.14
Požadavky: Android: 4.2 a vyšší
No changelog provided
https://userupload.net/nbqr9991jvmn
https://uploadrar.com/vq1cavbcg2ly
https://dropgalaxy.in/k9lqz3s6erdu
https://webshare.cz/#/file/ABVQLbsBlc/weather-forecast-2019-vip-4allmobile-eu-apk
