12. 09. 2019 15:32
Personal Finance Pro Cost accounting Family budget
Personal Finance Pro Cost accounting Family budget v1.8.4.Pro [Paid]
65,-Kč
Požadavky: Android 6.0 a vyšší
Popis: Aplikace Personal Finance umožňuje sledovat výdaje.
https://play.google.com/store/apps/details?id=vitalypanov.personalaccounting.pro&hl=en
https://uploadrar.com/j7n6eew591ri
https://dropapk.to/h5ldjmhog7fg
The Personal Finance application allows you to keep track of expenses.
Identify weaknesses and strengths in their personal finances, optimize costs, increase revenues, improve monthly balance.
If You do not know where the money disappears, then Personal Finance will help with the effective management of Your expenses. This is an extremely simple but very effective cost accounting application.
The Personal Finance app for mobile phone is a very convenient way to control and plan Your personal budget.
If You have already tried to keep records in an Excel spreadsheet or just a handwritten notebook, and then threw the case, the application Personal Finance, because of the simplicity of working with it, and instant availability, will help You bring it to its logical end - creating an effective ballance, output in plus and as a result of achieving Your financial goals.
If You haven't been able to save up for a long time: a vacation, a car, or any other major purchase, then using the app to account for expenses on a daily basis, You can quickly achieve these goals. With constant use of the application, You will quickly find weaknesses in Your budget and start saving wisely.
The free version of the application has all the necessary basic functions for cost accounting. But if You want to use all the features of accounting, we recommend using the Pro version of the application, with advanced features.
Pro version Features:
✓ Multi-currency accounting
You can create and manage accounts in different currencies. You can monitor total values of all accounts and articles in one, base currency
✓ Get more accounts
You can create more accounts. You can create and manage accounts as many as you want. And you can assign any available currencies
✓ New income and outcome articles
You can add more new articles. You can create new income and outcome articles. And use any available icons for them
✓ QR voucher barcode
You can scan QR barcode from Your cash voucher. This allows you to enter new outcomes more faster and conveniently for Your. You can make an expense directly in the store by simply scanning the cashier's check
✓ Budgets and limits
You can create and use any number of budgets. This allows You to control Your finances more effectively
✓ Widgets. Full functionality
You can add a widget to Your phone screen. This will allow you to always have in front of your eyes the most important information on the state of Your finances. And also get quick access to the most frequently used functions of the application from the widget
✓ Dark theme
You can use the dark (night) theme in the app interface. The dark theme reduces the brightness emitted by Your device's screen and also helps to improve visual ergonomics by reducing eye strain, and makes it easier to use the screen in low light conditions. Also, the dark theme saves battery power
✓ Password protection
You can protect Your data in the app by setting a password and security question
✓ Fingerprint authentication
You can use your fingerprint to enter the app. Just one touch and the app is unlocked. This saves time, and you do not need to remember anything (Note: the fingerprint can only be used together with the pin code and the secret question, in which case it was possible to restore access to the application)
✓ Backup and Restore
You can backup and restore Your data from Free version of Personal Finances to Pro and vice versa. If you already have transactional data in free version you can easily transfer it to the Pro version
20. 09. 2019 17:09
Re: Personal Finance Pro Cost accounting Family budget
Personal Finance Pro Cost accounting Family budget v1.8.6.Pro [Paid]
65,-Kč
+ Implementace analýzy sms zpráv
✓ Opraven problém s jazykem při použití společně s temným motivem
+ Další ikony
✓ Opraveny některé další problémy
https://www.uploadship.com/c0bf4b38d1abf9b4
https://uploadrar.com/cv64sw4ej10a
https://dropapk.to/n7bv0r2vq99k
26. 09. 2019 12:04
Personal Finance Pro Cost accounting Family budget v1.8.7.Pro [Paid]
65,-Kč
Implementovaná funkčnost plánovaných transakcí.Opraveny některé problémy.
https://www.uploadship.com/fb9f2e20e1d0f082
https://uploadrar.com/2yvmxyqbuuac
https://dropapk.to/fyv05fgurz1w
02. 10. 2019 16:36
Personal Finance Pro Cost accounting Family budget v1.8.8.Pro [Paid]
https://www.uploadship.com/adf5ed67a84fc79e
https://uploadrar.com/t5wpp7jxfx33
https://dropapk.to/9dq5cn89jzdo
24. 11. 2019 07:47
Personal Finance Pro Cost accounting Family budget v2.1.2.Pro [Paid]
70,-Kč
Požadavky: Android 6.0 a vyšší + SAI
Přidány podrobnosti podle podkategorií.Statistiky přidaných příjmů.
https://www.uploadship.com/90f2a1380296bdba
https://uploadrar.com/nfpwbipaq73n
https://dropapk.to/g2l5fvvg5la2
30. 12. 2019 08:44
Personal Finance Pro Cost accounting Family budget v2.2.3.Pro [Paid]
55,-Kč
Zlepšení kvality a stability aplikace
https://www.uploadship.com/47e9186ac1a09041
https://uploadrar.com/u5nfbbhzys9i
https://upload.ac/jnmhvkj23osc
https://webshare.cz/#/file/3x7O941f7f/personal-finance-pro-cost-zip
