20. 09. 2019 07:07
MeteoScope Accurate Weather
MeteoScope Accurate Weather v2.1.6 [Patched]
Požadavky: Android
4.2 a vyšší
Popis: MeteoScope je rychlá a krásná povětrnostní aplikace, pomocí které si můžete snadno naplánovat svou dovolenou, výlet a pohodlný pobyt nejen ve vašem městě, ale i v jiných regionech!
https://play.google.com/store/apps/details?id=com.izolentaTeam.MeteoScope
https://dropapk.to/1rc5273uopdv
https://uploadev.org/3xven9aek3vc
https://uploadrar.com/rmdrnrqrxag8
https://upload.ac/4y1c5gg8lsjz
https://mixloads.com/nnuys2f9sbvj
Accurate weather forecast:
A detailed weather forecast is available for you all day, as well as within two weeks.
The current weather forecast is available in one-hour steps and allows you to control the situation exactly and be ready for any weather conditions.
Data in all regions is continuously updated.
Our information partners are not hydrometeorological centers, but an international company with dozens of meteorological satellites in orbit and hundreds of observation points on the surface of the Earth.
Features and functions:
- Easy and modern application interface
- Widget for the main screen, with the ability to select colors depending on your color preferences
- Weather alert at a convenient time for you
- Displays the current temperature in the status bar.
- Ability to customize the interface and weather data (indicators / units)
- The most accurate database of cities and locations.
And also, the undoubted advantage of this application is that the last downloaded forecast is available to you without access to the Internet. Just enter the program or look at the widget.
Before starting the application requests several permissions:
Location- to find your location.
Wi-Fi connection information - if GPS is not available, this will roughly determine the location.
Download MeteoScope and stay one step ahead of the rest!
The application is completely free and does not collect personal data. Dotazy na SZ.
28. 01. 2020 16:58
MeteoScope Accurate Weather v2.2.1 [Patched]
Požadavky: Android
4.2 a vyšší
Chyby opraveny, stabilita aplikace se zlepšila.
https://www.uploadship.com/28a535adddc2765f
https://dropapk.to/svb8kg4i05id
https://upload.ac/p7c0kbhpq67i
https://uploadrar.com/lkkmb7xvvzo1
https://webshare.cz/#/file/6jz2162755/meteoscope-v2-2-1-premium-apk
Naposledy upravil(a)
milann70 dne 01. 05. 2020 15:51, celkem upraveno 1 x.
29. 01. 2020 21:43
MeteoScope Accurate Weather v2.2.2 [Premium]
Požadavky: Android
4.2 a vyšší
Chyby opraveny, stabilita aplikace zlepšena.
https://dropapk.to/o86o6e65vj3f
https://upload.ac/7fzsepa7cxt9
https://www.uploadship.com/ca2f2850c552ab78
https://webshare.cz/#/file/7kA1oY6l55/meteoscope-2-2-2-premium-apk
05. 04. 2020 20:23
MeteoScope Accurate Weather v2.3.0 [Premium]
Požadavky: Android 4.2 a
vyšší
https://www.uploadship.com/b12f5bd85293796a
https://dropapk.to/g3lomte559wn
https://upload.ac/ivwq35bmfviw
milann70 dne 01. 05. 2020 15:50, celkem upraveno 1 x.
25. 04. 2020 16:42
MeteoScope - Accurate Weather v2.3.1 [Premium]
vyšší
https://www.uploadship.com/cc08020cc1d64532
https://dropapk.to/pb1nbolffgie
https://upload.ac/bb21yz0tehpd
https://uloz.to/file/7Vu4DLqdhGG9/meteoscope-v2-3-1-premium-apk
https://webshare.cz/#/file/8tOs9p4dh2/meteoscope-v2-3-1-premium-apk
01. 05. 2020 15:58
MeteoScope Accurate Weather v2.3.2 [Premium]
vyšší
https://www.uploadship.com/6c1e06101d121960
https://uploadrar.com/3yczbqv7juvu
https://dropapk.to/ml935tvftg4m
https://upload.ac/2i1qn79787hm
https://ulozto.net/file/ywAbdOltwRWd/meteoscope-v2-3-2-premium-apk
https://webshare.cz/#/file/uVaUzvpTJR/meteoscope-v2-3-2-premium-apk
03. 05. 2020 11:23
MeteoScope Accurate Weather v2.3.3 [Premium]
vyšší
https://www.uploadship.com/0f242c8dfc49ba07
https://uploadrar.com/lwayf2m2azbb
https://dropapk.to/ufftvbmvzsyy
https://upload.ac/n58t2y8rwutm
https://uloz.to/file/DqO5FOe8mEfV/meteoscope-v2-3-3-premium-apk
https://webshare.cz/#/file/i0W5R3pZBL/meteoscope-v2-3-3-premium-apk
04. 05. 2020 16:34
MeteoScope Accurate Weather v2.3.4 [Premium]
vyšší
https://www.uploadship.com/9cc972b90dd3b85e
https://uploadrar.com/86tifeax23xb
https://dropapk.to/dm2jkti2e5er
https://upload.ac/hohe9lxcoh2s
https://uloz.to/file/vhjIZkW8oak6/meteoscope-v2-3-4-premium-apk
