Popis: Smart Clean je nejvýkonnější čistič nevyžádaných souborů (nežádoucí soubory), jaký kdy byl na Androidu vytvořen.
https://play.google.com/store/apps/details?id=com.xtraszone.smartclean&hl=en
https://www.uploadship.com/de22ab7c4426cca2
https://uploadrar.com/b2iq4lxpuwa1
https://dropapk.to/4f6tl8l7ejoo
It has the following features:
1. Log Files:
Removes logs files and folders from every location.
2. Cache Files:
Removes caches without removing your important files.
3. Temporary Files:
Removes temporary files and folders which sometimes not gets deleted by apps and results in storage consumption.
4. Duplicate Files:
Scans clone files very fast without removing original files from Duplicates.
5. Blacklist Files:
Removes all the files which is present in Blacklist
Unnecessary files / folders which are automatically created with time could be kept inside blacklist to remove them automatically on every scan.
6. Blacklisted File Extensions:
Removes all those files which have blacklisted extensions
(i.e. whose extensions are present in "Extensions Blacklist")
Simply insert those extensions in "Blacklist Extensions" separated by commas without including period.
7. Hidden Files:
Removes all those files and folders which are hidden to users (which are started with a period).
CAUTION: Make sure to add important hidden files and folders into whitelist to prevent them from deleting at the time of scan.
8. Unnecessary Big Files:
Remove all large files without fearing of loosing your favourite movies, music, apk and many more important big files.
9. Empty Files:
Removes all empty files.
i.e. Files which don't have any contents in it.
10. Empty Folder:
Removes all the folders which are empty.
11. Whitelist Files/Folders:
This feature is developed to save some of those files or folders which are important to the user but occurs in category of logs, cache, hidden, unnecessary large files, etc...
Simply put those files/folders into white list and this will not going to scan those folders / files.
12: Data Backup & Restore:
This feature is developed to backup all the data of Smart Clean including blacklist, whitelist, and preferences data.
