Požadavky: Android 44 a vyšší
Popis: Pigmenty přináší krásné barevné palety.
https://play.google.com/store/apps/details?id=com.sorincovor.pigments&hl=en
https://www.uploadship.com/6807d8ff5eecbbd9
http://ul.to/9b2x14kg
https://upload.ac/8cqbpx1he2yn
https://webshare.cz/#/file/44xoH2ik5C/pigments-1-66-apk
★ Simple - Generate color palettes with a simple tap. You can select the color harmony used to generate the color scheme (monochromatic, analogous, complementary, triadic, tetradic or compound).
★ Adjustable colors - The colors can be tweaked by using RGB and HSV sliders or by editing the HEX code.
★ Adjustable number of colors - Each color palette can have between 2 and 8 colors.
★ Easy reorder - The order of the colors can be changed by drag and drop.
★ Lock colors (Premium only) - Lock colors and prevent them from changing when generating a new color scheme.
★ Simulate color blindness - Validate the accessibility of a color palette by simulating color blindness (protanopia, protanomaly, deuteranopia, deuteranomaly, tritanopia, tritanomaly, achromatopsia, achromatomaly).
★ Image color picker (Premium) - Create color palettes from images either by selecting the colors manually or using the auto pick feature. The images can be loaded from your device or from a link.
★ Isolation mode - Distance the colors.
★ Easy undo - You can iterate through the generated color palettes or undo any tweaks made to the colors by swiping left or right.
★ Save for later - The palettes can be saved, locally, in your library.
★ Export - Export the resulted color palettes in various formats.
★ Share - Create a link to a palette and share it with other users.
