Témata, skiny a zvuky pro zkrášlení vašeho iGA
18 příspěvků
diMkaWA skin pro iGO Primo 2.0.x
baron_cz
29. 12. 2011 17:24
diMkaWA skin P 1.5.6 pro iGO Primo 2.0.x
Požadavky: nainstalované iGO Primo 2.0.x
Podporovaná rozlišení: 320x240, 480x234, 480x272, 800x480
Obsah: archív obsahuje 2 verze skinu, font a utility
Stažení skinu diMkaWA skin P 1.5.6:
http://www.igo8mods.com/diMkaWA_P156.rar
diMkaWA skin P 1.5.6 pro iGO Primo 2.0.x - portrait / landscape
Podporovaná rozlišení: 320x240 + 240x320, 640x480 + 480x640, 400x240 + 240x400, 800x480 + 480x800
Pro správnou funkci je potřeba použít tento data.zip post2538692.html#p2538692
Stažení skinu diMkaWA skin P 1.5.6 portrait / landscape:
http://www.igo8mods.com/diMkaWA_P156_pt_ls.rar
baron_cz
30. 12. 2011 21:31
Re: diMkaWA skin P 1.5.1 pro iGO Primo 2.0
Do 1.příspěvku viewtopic.php?p=2514347#p2514347 přidána nová verze skinu diMkaWA skin P 1.5.1.
Changelog: ver. P.1.5.1
1. Fixed inaccuracy, which led to a permanent establishment crash.txt (with records REPOSITORY).
2. The ability to create lock for direction:
- It is possible to choose the direction the lock (on the route / backward / both directions);
- This method allows you to lock the block several segments of the road network;
- In spite of the selected points (start, finish) in the middle segments, blocking the map shows and acts from beginning to end extreme segments.
Mini-statement:
- Entrance to the lock screen - Menu path / More / Lock for direction;
- Choose a starting point by clicking on the map (address of the selected position is displayed at the top);
- Switch the selection mode endpoint (only available after the initial point);
- After selecting the endpoint by clicking on the map (address of the selected position is displayed at the top) is calculated once the temporary route, along the entire length of which will be blocked segments;
- If the points are chosen correctly, out of the lock screen is not necessary, at once, you can click on the map to move the point;
- Choose the direction of the block: direct (from the start and end points) / reverse / both directions;
- Reaffirm the establishment, change / no change intervals.
- In order to distinguish these from the standard single-block segments (as they appear in a list), with the direction of the lock will have a name like "starting point URL address of the endpoint type blocking direction"
3. Other minor bug fixes.
baron_cz
24. 01. 2012 23:41
Re: diMkaWA skin pro iGO Primo 2.0
Do 1.příspěvku viewtopic.php?p=2514347#p2514347 přidána nová verze skinu diMkaWA skin P 1.5.2.
Changelog: ver. P.1.5.2
1. Enlarged and redrawn pointers maneuvers in the booth for all permits (thanks Andron66).
2. Arrow in the cab (on the top right button menu) now shows the next waypoint.
3. Added ability to disable the phrase "unit of measurement speed limit" (km / h, etc.) in TTS Pro alerts to increase the speed limits and road cameras.
4. Changes to split-screen (mode "Objects POI"):
- When you search around your current location adds the ability to search for input angle (the angle between the direction of motion and the radius of the search sector, ie 90 ° - 90 ° left it on the direction of + 90 ° to the right of the direction of motion), taking into consideration the direction of motion at the current location ; for the search mode, the search distance is not configured (using 50 km);
- Added a search option "Along Route", in this embodiment displays the distance: how to increase the route upon arrival at a certain point + distance along the route (in this case around the current location is displayed in a straight line distance) to a certain point;
- Added ability to use the category list POI (before there was one group) (8 items); - Added ability to save and restore the category lists used POI (for quick switching between them);
Retained only the first page of search, including and for the regime "Route summary".
5. Changed logic TTS Pro alerts, including Fixed inaccuracy, which led in some cases to "silence" warning maneuvers until the passage maneuver (search for errors and tests thanks Andron66).
6. Other fixes.
baron_cz
18. 02. 2012 18:53
Do 1.příspěvku viewtopic.php?p=2514347#p2514347 přidána nová verze skinu diMkaWA skin P 1.5.3.
Changelog: ver. P.1.5.3
1. Minor corrections: - The dynamic panel buttons (call split-screen, TMC, parking Vosloo finish) when not in use all the buttons in the right menu will now be in this unused site (if the size of the panel allows);
- To take an alternative route without the preview, you can click on the icon of maneuver in the panel reports on the alternative route;
- Other technical (and not only) of the amendment.
metroparade
Omnia II
23. 02. 2012 18:05
24. 02. 2012 19:32
A kam se ty soubory mají dát? Čekal jsem, že tam budou jen dva soubory jeden pro day a druhý pro night, který mám kam použít? A co s tou složkou font a utility?
maros888
11. 10. 2010 18:22
24. 02. 2012 20:13
@metroparade
Je tam len 1 súbor a daj ho do content/skin a v navi si ho vyber aj pre deň aj pre noc. Utillity a Font daj do zložky Primo resp. tam kde máš umiestneny exe súbor pre spušťanie navigácie.
Utility slúži pre mapchanger a fixáciu gps pre pda.
Doporučujem : dimka - tomsoft .......vylepšenie skinu dimka
Je tam aj navod na implementáciu a funkčnosť skinu.
http://www.tomsoftware.net/navigace-igo-primo.aspx
metroparade
Omnia II
23. 02. 2012 18:05
24. 02. 2012 20:57
Díky, teď pro změnu jiná věc, před tim mi při nabíhání aplikace problikla obrazovka kalibrace. Tomsoft dimkou mi kalibrace vyskočí a nezmizí, prostě se čeká, až ji udělám a to při každém spuštění... Proč?
maros888
11. 10. 2010 18:22
24. 02. 2012 21:08
Ak maš navigáciu na PDA mala by ti kalibrácia nasločiť a automaticky ukončiť.
Ak máš navigáciu na PNA tak vymaž v sys.txt sekciu
[utility]
calibratefix=1
baron_cz
24. 02. 2012 23:17
to metroparade: to máš do Omnie, pak se podívej do Utility\esc.nfrun, na 1.řádku je
SLEEP "300"
tak místo 300 zapiš vyšší hodnotu, např. 500 nebo 1000. Pak by to mělo fungovat.
Luky.Sipak
Galaxy S4 i9295
22. 05. 2011 18:48
04. 08. 2012 22:00
lze komplet počeštit tomsoft?
Galaxy S4 i9295
18 příspěvků
