10 příspěvků •Stránka 1 z 1
SuperWall Video Live Wallpaper
23. 03. 2016 03:14
SuperWall Video Live Wallpaper v1.6.2
Popis: TLDR: Yes, it can play MKV files! SuperWall is a Live Wallpaper app that allows you to set portrait and landscape video's (Launcher pending) as your phone/tablet wallpaper.
https://play.google.com/store/apps/details?id=com.jasonng.superwall
http://ulozto.cz/xaDmhKcu/superwall-video-4allmobile-eu-apk
http://ulozto.net/xvA9cgBQ/superwall-video-4allmobile-eu-apk
https://webshare.cz/file/76g6y325c2/superwall-video-4allmobile-eu-apk
SuperPersonalize your Android device with your favorite videos! SuperWall will automatically rotate the two video wallpapers based on the orientation of your device.Got portrait video's that you have no use for? Well now you do! SuperWall is the perfect platform to finally use those portrait videos that you have. Portrait video's are terrible for Youtube, but perfect for SuperWall. Set those beautiful family video's of your wedding, kids, dogs, cats, llamas?, etc... as your Android wallpaper. Don't have any portrait videos? Start taking some today, or convert your existing video's (feature coming in future release)!If you use a launcher that also supports landscape mode (ie. Google Now Launcher, Smart Launcher 3, etc), then you can optionally set a landscape video for when your phone is on its side. Perfect for tablets!
07. 06. 2017 02:27
Re: SuperWall Video Live Wallpaper
SuperWall Video Live Wallpaper v5.1.2 [Paid]
Co je nového: Obrázek
Oprava chyb.
https://ulozto.net/!YuaqxedJV6ej/superwall-5-1-2-apk
https://webshare.cz/file/4nV3Kx3677/superwall-5-1-2-apk
Naposledy upravil(a) milann70 dne 23. 03. 2019 01:56, celkem upraveno 1 x.
01. 03. 2019 14:37
SuperWall Video Live Wallpaper v10.2.2 [Paid]
21,-Kč
Aktualizovaný motor pro vykreslování videa. Více stabilní a lepší výkon.
Opravena chyba s vykreslením malého videa.
Opravena chyba, při které se při výběru videa havarovala aplikace pro některé telefony.
Opraveny problémy s měřítkem na určitých zařízeních.
https://upload4earn.org/v8bmwy3vzsdf
https://dropapk.com/cwf7jwz2u5q1
https://upload.ac/bnylsymp44f0
02. 03. 2019 19:24
SuperWall Video Live Wallpaper v11.0.3 [Paid]
65,-Kč
Banda nových funkcí a oprav chyb.
https://douploads.com/wbthftbytzjb
https://upload4earn.org/zhzweqipr4jn
https://dropapk.com/4mdt7xhrynuf
https://speed4up.com/9omk2lkcuojn.html
https://uploadbuzz.org/1f857pwwsq3k
http://ul.to/yt1wr1qy
Naposledy upravil(a) milann70 dne 23. 03. 2019 01:55, celkem upraveno 1 x.
23. 03. 2019 01:54
SuperWall Video Live Wallpaper v11.1.4 [Paid]
65,-Kč
Widget!
Stabilita.
Oprava chyb.
Přidána funkce automatického otočení zakázání.
Výrazně zlepšené doby načítání aplikací.
https://douploads.com/ottse8qhcowt
https://upload4earn.org/1ze5i2w1i2h2
http://ul.to/prs4zezs
https://uploadrar.com/dfcajnhstek5
21. 04. 2020 18:02
SuperWall Video Live Wallpaper v12.0.0 build 311 [Paid]
Aktualizujte všechny knihovny na nejnovější verze.
Opraveny některé problémy se stabilitou. Pokud dojde k chybě aplikace, bude se video přehrávat z aktuální pozice.
Funkce Play in Background povolena, jak požadovali někteří uživatelé.
Experimentální použití na vlastní nebezpečí :D
Zjednodušené nabídky nastavení.
Čtený widget.
Nová funkce pro přidání všech videí z vybrané složky v zařízení.
https://up-load.io/84shy5g8vqyp
https://www.uploadship.com/cca87dc9b1db5086
http://ul.to/fxn96pdz
https://mega4up.com/tci3fiuc5cot
https://www.file-up.org/n49x7m8ap2k1
24. 04. 2020 10:08
SuperWall Video Live Wallpaper v12.0.3 build 315 [Paid]
Funkce Play in Background povolena, jak požadovali někteří uživatelé. Experimentální použití na vlastní nebezpečí.
Čtený widget.
https://up-load.io/pfwc1inmuddl
https://www.uploadship.com/ba9215d8ef0507c3
http://ul.to/crmr4igk
https://mega4up.com/j9cxkmn2ww5e
https://www.file-up.org/v40l1l4a5spk
https://uloz.to/file/I7EA8oFk393S/superwall-v12-0-3-apk
https://webshare.cz/#/file/yHp1tJRAtS/superwall-v12-0-3-apk
26. 04. 2020 08:23
SuperWall Video Live Wallpaper v12.0.6 build 318 [Paid]
Update all libraries to the latest versions.
Fixed some stability issues. Video will replay from the current position if the app crashes.
Play in Background feature enabled, as requested by some users. Experimental, use at own risk.
Streamlined settings menus.
Readded widget.
New feature to add all videos from a selected folder on device.
https://up-load.io/vi2cqhkhlnoa
https://www.file-up.org/pvvuqjnb1y9l
https://mega4up.com/7o04608hxkqs
http://ul.to/r6k2y4st
https://uploadrar.com/j6s3g21k7wgn
03. 05. 2020 08:26
SuperWall Video Live Wallpaper v12.1.0 build 322 [Paid]
Vylepšená stabilizace aplikace celkově.
Nový zavaděč obrázků, žádné další obrazovky při spuštění aplikace.
Aktualizujte widget.
Oprava chyb.
https://www.uploadship.com/bf87030d267e7caa
https://userupload.net/v0sj8ki5s1er
https://uploadrar.com/cptmy3yq8a1v
http://ul.to/hokqxe3y
18. 05. 2020 08:34
SuperWall Video Live Wallpaper v12.1.1 build 325 [Paid]
Čtený widget.
https://dropgalaxy.in/sfjc9jdpboh7
https://up-load.io/1um8v9hza45f
https://www.uploadship.com/9553b8e07ec79c5b
https://uploadrar.com/n6t69u9tl3zm
http://ul.to/pfa74tqd
https://mega4up.com/s4v4p52c2ko5
https://uloz.to/file/iINAa4Y8FscP/superwall-v12-1-1-build-325-apk
https://webshare.cz/#/file/YxZrr3wfGf/superwall-v12-1-1-build-325-apk
