Amphetamine - Icon Pack
18. 08. 2017 03:12
Amphetamine - Icon Pack v1.2.9
30,-Kc
Amfetamin je apka,která se snaží zlepšit styl Android ikony.
https://play.google.com/store/apps/details?id=com.ayushm.icons.amphetamine
https://ulozto.sk/!j3sls8azkTiN/amphetamine-1-2-9-apk
https://webshare.cz/file/42oc24nn7Z/amphetamine-1-2-9-apk
Features
• 600+ icons
• Alternative icons for nearly every app
• 30 HD wallpapers
• Icon requests
• Auto apply from dashboard
Just like every other icon pack you've used, Amphetamine works with almost every popular launcher on the Play Store:
• Nova Launcher
• Evie Launcher
• Action Launcher
• ADW Launcher
• Apex Launcher
• Atom Launcher
• Aviate Launcher
• CM Theme Engine
• GO Launcher
• Holo Launcher
• Holo Launcher HD
• LG Home
• Lucid Launcher
• M Launcher
• Mini Launcher
• Next Launcher
• Nougat Launcher
• Smart Launcher
• Solo Launcher
• V Launcher
• ZenUI Launcher
• Zero Launcher
• ABC Launcher
• and MORE
For the following launchers, apply the icon pack directly from the launcher's settings:
• Arrow Launcher
• ASAP Launcher
• Flick Launcher
• Cobo Launcher
• Line Launcher
• Mesh Launcher
• Peek Launcher
• Z Launcher
• Launch by Quixey Launcher
• iTop Launcher
• KK Launcher
• MN Launcher
• New Launcher
• S Launcher
• Open Launcher
Amphetamine is partially compatible with the following launchers:
(Only supports the launcher's icon picker, you need to apply icons manually (Tap, hold then edit))
24. 05. 2020 03:43
Re: Amphetamine - Icon Pack
Amphetamine Icon Pack v3.1 [Patched]
No Chnagelog
https://www.uploadship.com/0ad2d71aa8c3b695
https://userupload.net/eihue4ko857p
https://up-load.io/a42hh876munj.html
https://mixloads.com/xa6e7frcvt76
http://ul.to/9131e1nw
08. 06. 2020 05:21
Re: Amphetamine Icon Pack
Amphetamine Icon Pack v3.2
Přidáno 50+ ikon.
Opravena kontrola licence.
Opravená adresa URL tapety.
https://www.uploadship.com/b6b7d9acae0c27f8
https://userupload.net/izk56gmszjya
https://up-load.io/z0x3vwqzx527
https://mixloads.com/h6ihfpec6fwv
http://ul.to/94sws80d
https://uloz.to/file/ZYGmNxPOPSRC/amphetamine-3-3-4allmobile-eu-apk
23. 06. 2020 00:30
Amphetamine Icon Pack v3.3 [Patched]
Přidáno 50+ ikon.
https://webshare.cz/#/file/vPz8arjvmt/amphetamine-3-3-4allmobile-eu-apk
24. 06. 2020 22:23
Amphetamine Icon Pack v3.4 [Patched]
Přidáno 40+ nových ikon.
Upraven systém požadavků na ikony. Nyní můžete odesílat žádosti o ikony jediným klepnutím.
https://userupload.net/id0jnh6eduvl
https://mixloads.com/nf2hq803u198
http://ul.to/7ry962qx
https://uloz.to/file/KeoS60Pb1Wjz/amphetamine-icon-pack-4allmobile-eu-apk
25. 06. 2020 07:31
Amphetamine Icon Pack v3.5 [Patched]
UI se mění.Aplikaci má velikost o více než 50% menší!
https://userupload.net/ho2zyw59x86f
http://ul.to/agqovp03
https://www.uploadship.com/a84c285ce0e08d07
https://uloz.to/file/PlnDiRSfvRi8/amphetamine-4allmobile-eu-apk
