55,-Kč
* 4705 Ikony s rozlišením 2K SuperHD + (300 × 300) pixelů!
* 4700 + podporované aplikace!
https://play.google.com/store/apps/details?id=com.cris87.miui_vintage
https://upload.ac/fvk90szyis4j
https://dropapk.com/5xqo8su10bp2
https://uploadev.com/sul52tblebz2
https://dailyuploads.net/9zj7oeod03xe
* Each icon Designed with extreme care in detail!
* quadrupling Rendering Process Icons!
* Automatic Masking for apps icons missing!
* Dynamic Calendar App for Stock & Google Calendar!
* Requests Free icons Missing directly through the app (3 for each issue)!
* Updated periodicals guaranteed!
ABOUT USE:
• This icon pack should be applied custom run. Pixel Launcher, Google Now Launcher and any other launcher that is preinstalled on the device do not support Icon Pack (for ZenUI Asus, LG Home, Home Xperia Except). There is no possibility to apply the launcher theme, which does not allow to change the icons. For this, please check before your launcher or ensure the boot launcher is compatible !!!
• With the new operating system Android 7.0 Nougat, LG has removed the Home icon support external packages and does not support the standard set of icons;
• To fully control the size of the icons, you must go to the LAUNCHER SETTINGS / ASPECT TURN OFF and “ICONS are normalized” ... The required action on NOVA LAUNCHER (and all other launches that provide this function) in the form of icons has already been normalized and does not require this option ; Otherwise, you could end up with a much smaller icon size!
COMPATIBILITY:
They are compatible with most of the main launchers on the PlayStore,
ABC, Action, ADW, Apex, Atom, Aviate, GO, Holo, HoloHD, ITOP, KK, Lucid, M, Mini, MN, New, Next, Nougat, Nova, S, Smart, Solo, V, ZenUI, Zero.
However, it can be used with many others that support icon launcher packages, but are not listed within the application itself, such as Arrow, ASAP, Evie, Cobo, Lines, Grid, N, Peek and Z Launcher, with Xperia Home and CyanogenMod Theme Engine, applied directly to the SETUP MENU, used by the LAUNCHER SECTION thematic / ICONS;
Compatibility with the LG HOME starting stock is not guaranteed (should work before Android 6.0, but I don’t have the opportunity to check personally), you can’t refer to the Samsung stock launcher, Huawei, Nubia, Meizu ...
The icon pack was tested personally smoothly:
NOVA grenade launcher;
APEX grenade launcher;
EVIE grenade launcher;
ACTIONS LAUNCHER 3;
HOLA grenade launcher;
YANDEX grenade launcher;
ZEN interface grenade launcher;
