Resicon Pack Adaptive
10. 05. 2019 19:37
Resicon Pack Adaptive (The Adaptive Icon Pack) v1 [Patched]
23,-Kč
Požadavky: Android: 8.0 a vyšší
Popis: Toto je adaptivní verze Resicon Pack Flat.
https://play.google.com/store/apps/details?id=sarsamurmu.resiconpack.adaptive
https://upload.ac/zczmwyyfwe14
https://dropapk.com/fsidaznq16rg
https://uploadev.org/3p2iik7ott2s
https://dailyuploads.net/p0zsjpydidvh
Read Description Carefully!!!
A cool set of Adaptive icons for the Supported Launchers. It's in active development and there will be frequent updates.
Features
- Icons By Sarsa Murmu (@sarsamurmu).
- On Cheapest Price Available.
- 500+ Adaptive Icons. (For Now, More Coming)
- Dynamic Clock Included.
- More Alternatives.
- High Resolution Icons (up to 432x432 px)
- Lightweight Size.
The Icon Pack is Supported by the Following Launchers -
- Rootless Pixel Launcher^
- Lawnchair Launcher v2^
- Hyperion Launcher^
- Lean Launcher^
- Nova Launcher
^ Marked Launcher Supports Icon Wiggling and Dynamic Clock.
How to Use:
Rootless Pixel Launcher: Go to Launcher's Home Settings. Then Choose the Icon Pack. Change the Shape as you want.
Lawnchair Launcher v2: Go to Launcher's Home Settings. Open "Theme", Then Choose The Icon Pack. Change the Shape as you want.
Hyperion Launcher: Go to Launcher's Home Settings. Open "Iconography", Then Choose Icon Pack. Change the shape as you want.
Nova Launcher: Go to Launcher's Settings. Open "Look & Feel", Then open "Icon Style", Choose Icon Pack. Change shape as you want.
Enjoy!
FAQs
Q: Why it says Device Unsupported?
A: Adaptive icons are introduced in Android 8.0. So, The Icon Pack only works on Android 8.0+ Devices.
Q: Why it is not working on my device?
A: It mainly works on AOSP Android 8.0 Based Firmware (Lineage OS, Resurrection Remix, AEX etc.). It's not guaranteed that the icon pack will work on Devices with Custom Shell. It's not the problem of Icon Pack, It's the Problem of OEM. By the way, you can get refund.
Q: How can I get all those Icon Shapes?
A: It depends on the launcher you're using. As many the launcher supports.
Q: Why the icon pack is dashboardless?
A: Icon Dashboard still do not support Adaptive Icons, that's why it doesn't have any dashboard.
If don't have Supported Device Then You Can Use the Static Version, "Resicon Pack - Flat".
02. 04. 2020 09:36
Re: Resicon Pack Adaptive
Resicon Pack Adaptive (The Adaptive Icon Pack) v1.0.2 [Patched]
Požadavky: Android 8.0 a vyšší
Opravené chyby
Přidáno 90+ ikon
Přidány ikony statických hodin
Přidány ikony složek
https://userupload.net/gglf784eet8y
https://up-load.io/ptymt1du4g26
http://ul.to/ikvxfvlf
https://mixloads.com/j3tjgwloysw0
28. 06. 2020 14:06
Resicon Pack Adaptive (The Adaptive Icon Pack) v1.0.7 [Patched]
Přidáno 80 ikon.Přidáno 90+ aktivit.
https://webshare.cz/#/file/VMxqJI53rO/resicon-pack-4llmobile-eu-apk
