MIXED - ICON PACK
Henry1
09. 09. 2009 07:54
30. 09. 2019 13:01
MIXED - ICON PACK
MIXED - ICON PACK v6.0 Paid
Requirements : ↑4.0.3
Overview : INFORMATION:
* 3615 Icons Resolution 2K SuperHD+(300 X 300)Pixel!
* 3600+ Supported Applications!
* 30 HD Wallpapers with Resolution 2K (2000x2000)Pixel!
* Each icon has been designed with extreme care of the details!
* Triple Icons Render Process!
* New Icons Saturation System!
* Detail Cleaning and Sharpness of Icons!
* Dynamic Calendar for App Stock & Google Calendar!
* Inquiry Icons Missing directly through the app (3 Free for each release)!
* Update Periodicals Guaranteed!
* Support, Support & Info on Future and Future Projects on My Site: http://www.cris87.altervista.org
INFO USE:
• This Icon Pack needs a custom launcher to be applied. Pixel Launcher, Google Now Launcher, and any other launcher that is preinstalled on the device do NOT support Icon Packs (Except for Asus ZenUI, LG Home, Xperia Home). There is no way to apply the theme to launchers that do not provide the ability to change icons. So please check your launcher first or download a compatible launcher !!!
• With the new Android 7.0 Nougat operating system, LG Home has removed support for external packet icons and does not support standard icon packs;
• For full control of the Dimensions of the Icons, you need to go to the LAUNCHER / APPEAR SETTINGS and DISABLE the "NORMALIZE ICONS" function ... Action required on NOVA LAUNCHER (and All other Launchers that provide this function) because the icons are already normalized and do not require this option; If you do not, you may find some smaller size icons!
COMPATIBILITY:
Most of the major launchers on the PlayStore are compatible,
ABC, Action, ADW, Apex, Atom, Aviate, GO, Holo, HoloHD, iTop, KK, Lucid, M, Mini, MN, New, Nougat, Nova, S, Smart, Solo, V, ZenUI, Zero.
It can still be used with many other launchers that support icon packages but are not specified within the application itself, such as Arrow, ASAP, Evie, Cobo, Line, Mesh, N, Peek and Z Launcher, with Xperia Home and with the CyanogenMod Theme Engine, DIRECTLY APPLICABLE IN THE SETUP SETUP MENU USED THROUGH THEME / ICONS SECTION;
Not Guaranteed Compatibility With the LG HOME Stock Launcher (should work up to android 6.0 but I have no way of personally verifying), Can not Apply to Samsung, Huawei, Nubia, Meizu, ...
The Icon Pack has been personally tested with no problems with:
NOVA LAUNCHER;
APEX LAUNCHER;
EVIE LAUNCHER;
ACTION LAUNCHER 3;
HOLA LAUNCHER;
YANDEX LAUNCHER;
ZEN UI LAUNCHER;
What's New :
v6.0
- ADDED POCO LAUNCHER SUPPORT!
- COMPLETE COMPATIBILITY WITH ONE PLUS LAUNCHER!
- 25 new badges;
- 3615 total icons;
- 3600+ applications;
- 30 Total wallpapers with 2K screen resolution;
- New alternative icons for different applications;
- Updated and optimized Xml and Java codecs;
More Info :
https://play.google.com/store/apps/details?id=com.cris87.mixed
Download :
https://uloz.to/file/FV1oSi3dmeqg/mixed-icon-pack-v6-0-apk
https://dropapk.to/1c6wbv7w6xsz
Henry1
09. 09. 2009 07:54
28. 10. 2019 07:17
Re: MIXED - ICON PACK
MIXED - ICON PACK v6.5 Paid
What's New :
v6.5
- ADDED SUPPORT FOR POCO LAUNCHER!
- FULL COMPATIBILITY WITH ONE PLUS LAUNCHER!
- 55 new badges;
- 3665 total icons;
- 30 total wallpapers with a screen resolution of 2K;
- Updated and optimized codecs Xml and Java;
More Info :
Download :
https://uloz.to/file/GDv11vRnjGoY/mixed-icon-pack-v6-5-apk
https://dropapk.to/ri0j9pbvwgmm
Henry1
09. 09. 2009 07:54
28. 10. 2019 17:38
MIXED - ICON PACK v6.6 Paid
What's New :
v6.6
- 35 new badges;
- 3700 total icons;
- 3700+ applications;
More Info :
Download :
https://uloz.to/file/rpOHMbkluCUC/mixed-icon-pack-v6-6-apk
https://dropapk.to/pghbtbdfoh7g
22. 11. 2019 10:22
MIXED ICON PACK v6.7 [Paid]
- 15 nových odznaků;
- celkem 3715 ikon;
- 3700+ aplikací;
- 30 celkem tapet s rozlišením obrazovky 2K;
- PŘIDANÁ PODPORA PRO POCO LaUNCHER!
- PLNÁ KOMPATIBILITA S JEDINÝM PLUS Launcherem!
- Nové alternativní ikony pro různé aplikace;
- Aktualizované a optimalizované kodeky Xml a Java;
https://dropapk.to/yg14061lcoq0
https://upload.ac/gb2bqz21q9y0
https://www.uploadship.com/471a99d5d831ae44
https://webshare.cz/#/file/5Eo47q1T9L/mixed-v6-7-p-apk
04. 01. 2020 12:48
Re: MIXED ICON PACK
MIXED ICON PACK v7.1 [Paid]
- 25 new badges;
- 3740 total icons;
[codehttps://dropapk.to/4c8zljjnl87k
https://upload.ac/6xt8so8tsbo4
https://www.uploadship.com/550f7bad115e8848
https://uploadrar.com/s7l0urfhrh0p
https://webshare.cz/#/file/7cr3zG4Dd6/mixed-v7-1-p-apk[/code]
Naposledy upravil(a) milann70 dne 19. 05. 2020 20:54, celkem upraveno 1 x.
19. 05. 2020 20:53
Mixed Icon Pack v8.1 [Paid]
- 35 nových odznaků;
- 3865 celkem ikon;
- 3800+ aplikací;
https://dropapk.to/7n58avrbut5g
https://mixloads.com/h2m00oosoi7e
https://uloz.to/file/qzcgoQPFhyta/mixed-v8-1-p-apk
https://webshare.cz/#/file/twF8AcitFv/mixed-v8-1-p-apk
