KLWP + KLCK + KWGT Maker
07. 02. 2020 14:38
KLWP + KLCK + KWGT Maker v3.44b3715 [Final] [Pro]
Popis: Nechte své zařízení Android vypadat jedinečně s Kustom nejvýkonnějším tvůrcem živé tapety všech dob! Pomocí svého úžasného editoru WYSIWYG (Co vidíte, je to, co získáte) můžete vytvořit vlastní návrhy a zobrazit všechna potřebná data najednou a také s úžasnými animacemi! Pokud jste hledali Rainmeter nebo Conky na Androidu, je to ono!
https://play.google.com/store/apps/details?id=org.kustom.wallpaper
https://play.google.com/store/apps/details?id=org.kustom.widget
https://play.google.com/store/apps/details?id=org.kustom.lockscreen
Stahuj zde: KLWP:
https://www.uploadship.com/21b093936c3ca9b6
http://ul.to/j3piqoa8
https://up-load.io/c8r2p6m7qm02
https://speed-down.org/zse9yxejgtdk
http://hulkload.com/0m2rohissi33
https://www.file-up.org/vn11uzmwiu2t
Stahuj zde: KWGT:
https://www.uploadship.com/fd42a7279e653350
http://ul.to/xei9g7gv
https://up-load.io/fjar5zm5n783
https://speed-down.org/phsixk4chzxr
http://hulkload.com/b9amgir3f9c2
https://www.file-up.org/8ieqoy1cb6q5
Stahuj zde: KLCK:
https://www.uploadship.com/0182c8ee723a0abe
http://ul.to/tj2otm9l
https://up-load.io/lf89b3kamg37
https://speed-down.org/4wno8ctnmoqf
http://hulkload.com/b4upknxwjw0p
https://www.file-up.org/go6a9dui7otd
With Kustom you can create customized Digital and Analog Clocks (with seconds hand), animated patterns, live map backgrounds, material wallpapers, sophisticated CPU/Memory meters, randomly changing images, scrolling images, gyroscopic effects and much much more. Imagination is the limit.
Launcher support
Animations works only on launchers that fully supports the Android standards, so for example Google Now Launcher and Nova Launcher are fully supported. Some others might have problems, the only known launcher with issues right now is GO Launcher (and this cannot be fixed by us).
You get:
- Some skin to start with
- Text with custom fonts, colors, sizes and effects
- Shapes like Ovals, Rects, Arcs, Triangles, Exagons and more
- Gradients, shadows, tiling and color filters
- Photoshop / GIMP like layers with overlay effects (blur, clear, xor, difference, saturation)
- Touch actions / hotspots on any object you create
- PNG / JPG / WEBp Image support
- Animations such as fading, scaling and scrolling based on screen position, touch, events...
- Magnetic sensors / gyroscope support for wallpaper motion or objects animations
- Complex programming with functions, conditionals and global variables
- Change Wallpaper based on time, location, weather, anything!
- Dynamic download of content via HTTP (live maps, weather and so on)
- Native music utilities (current playing song title, album, cover)
- Tasker support
- A huge amount of data to display (like date, time, battery, calendar, weather, astronomy (sunrise, sunset), CPU s
20. 03. 2020 06:31
Re: KLWP + KLCK + KWGT Maker
KLWP + KLCK + KWGT Maker v3.45b7410 [Final] [Pro]
Vyšší maximální rozlišení bitmapy (mělo by se na některých předvolbách opravit rozmazaný obraz)
Opravené problémy v KWGT s přepínáním signálu / wifi
Opraveny problémy s pluginy s KWGT (broadcast)
Opraveny problémy s více widgety pomocí různých pozadí obrázku
Opravuje problémy s přepínáním / vzorcem, který se nezapíná / nevypíná
Oprava proudu baterie na zařízeních Samsung
Přidána tradiční čínština k jazykovým možnostem
https://www.uploadship.com/a492426e514425a0
https://up-load.io/bjyanndsedka
https://dropgalaxy.in/2m6lr3hrywgs
https://www.file-up.org/pdvk8kl9faoe
https://intoupload.net/k6b4mcft94qc
http://ul.to/f4hya2vr
https://uloz.to/file/DoXc7G2fasYG/appshut-close-running-apps-premium-apk
Stahuj zde: Stahuj zde:
Naposledy upravil(a) milann70 dne 29. 05. 2020 18:25, celkem upraveno 1 x.
12. 04. 2020 23:41
KLWP + KLCK + KWGT Maker v3.45b7815 [Final] [Pro]
Higher max res for bitmaps (should fix blurry images on some preset)
Fixed issues in KWGT with signal/wifi toggles
Fixed plugins issues with KWGT (broadcast)
Fixed issues with multiple widgets using different image backgrounds
Fixes issues with toggles / formulas not switching on / off
Fixes battery current on Samsung devices
Added traditional Chinese to the language options
Mod Info:
Pro features unlocked no additional key needed.
Stahuj zde: KLWP:
https://www.uploadship.com/6d43a696e27ce39e
https://up-load.io/9m8mu7ptlgwd
https://www.file-up.org/l9rjomwd2tlq
https://intoupload.net/bvosc0gqr4bi
http://ul.to/uiopbso6
Stahuj zde: KWGT:
https://www.uploadship.com/fa7952bbd7bcb6f0
https://up-load.io/fajtrelgwlvo
https://www.file-up.org/ytwzfvd0ehnv
https://intoupload.net/iil6uvr0054b
http://ul.to/bd7ap54u
Stahuj zde: KLCK:
https://www.uploadship.com/192d9042b45f9ce6
https://up-load.io/6ezh60e6sxfn
https://www.file-up.org/do23ayk9a7ri
https://intoupload.net/px4ud6t5na5m
http://ul.to/0qto50yi
29. 05. 2020 18:24
KLWP + KLCK + KWGT Maker v3.46b14609 [Pro]
New scale modes in Bitmap Module (fit height, center fit and center crop)
New text module fit box mode to control height and width
New hex and decimal conversion in mu()
New count text occurences with tc(count)
Fix palette never returning black as a color
Fix in current not working on some device
Fix ce(contrast) returning black too often
Fix forcing Chinese language not working
KLWP Fix visibility issues during animations
Mod Info:
Stahuj zde: KLWP:
https://dropgalaxy.in/4vzpzbk25j0x
https://www.uploadship.com/0ceda8e7af970065
http://ul.to/csxvjep8
https://up-load.io/nkm0br4k9379
https://mega4up.com/c0ng8gmsvqui
Stahuj zde: KWGT:
https://dropgalaxy.in/9bfaa50i16qy
https://www.uploadship.com/fffd786c3f94c291
http://ul.to/xbwpiact
https://up-load.io/hs4bojvtb2kc
https://mega4up.com/97g42b7vksns
Stahuj zde: KLCK:
https://dropgalaxy.in/efanb9k98yd2
https://www.uploadship.com/1f9f1455a5f10424
http://ul.to/z0coiy4z
https://up-load.io/ml7e1tz5gski
https://mega4up.com/9mphjfp5kxx9
Furdik
Realme 5
25. 05. 2008 11:04
08. 08. 2020 07:37
KWGT key (verze E)
Nejprve musíte nainstalovat aplikaci KWGT z PlayStore
https://play.google.com/store/apps/details?id=org.kustom.widget.pro
https://uloz.to/file/QU1B4QOGgMHd/org-kustom-widget-pro-9-apk
Furdik
Realme 5
25. 05. 2008 11:04
20. 08. 2020 18:17
Nainstaluj free verzi z PlayGoogleStore, poté použij níže přiložený PRO Key
KWGT Pro key
https://userupload.net/1yedjmwnd91d
KLWP Pro key
https://userupload.net/d14lz4qsdmut
KLCK Pro key
https://userupload.net/4a0k8siwkl0d
