Požadavky: DUD
Popis: search contacts when dial Apart from Edit Before Call/SMS, Smart Dial provides the fastest and easiest way access to your contacts, by searching any number and name that match your keyword. E.g. “537″ matches contacts with name “Jerry” and any number starts with “537″. You can even define your contact’s alternative keyword, try assign “honey” to your wife or love one:)
Features
- edit before call/SMS and pre-stored prefix
- search contacts by numbers, names and Pinyin for Chinese characters;
- import Windows Live and Gmail contacts from phone;
- define the candidate keyword of a contact;
- numbers of a contact in search result are sorted by best match
- sync your contacts between your phone and computers via Smart Dial Agent
The Smart Dial Agent is a supplement runs on your desktop computer, it provides an option to manage your contacts easier. Plus some extra functions like merge up to 5 contacts into one, import contacts from CSV file, and add a photo to your contact.
** Important notes for first time usage **
- You need to create a free account via phone to enjoy the storage services
- After import contacts from Live or Gmail, you need to upload first in order to edit with Smart Dial Agent
- Support and Smart Dial Agent download website: JerryHuang.net
- For email support please visit above website, click “Contact” link at the top
http://jerryhuang.net/page/Smart-Dial.aspx
http://www.uloz.to/10391443/smart-dial-v1100-xap
http://www.zshare.net/download/89475332d784674f/
