To si přeložte sami
This is WM6.1 stripped ROM.
It has:
Kernel: wm6.1 19199
OS: wm6.1 19199
PP: 6MB
* This ROM is based on freepk's shift from (which was based on 544rus ROM). This ROM contains special changes from 546rus ROM (passwords fix, gsm drivers fix e.t.c.)
* This ROM have lot's of changes inside from original wwe or rus ROM.
* This ROM is as light as possible.
* This ROM supports both SD and SDHC cards.
* I advise you to use cabs from this post for MMS and USSD. (They are not integrated to rom)
Changes from v8 to v9:
* Windows Media Player fix (scaling is on now)
* Battery fixed. Got back to full suspend mode, but with special fix for sounds. It's all ok with messangers now.
* Small registry fixes.
I consider v9 to be RC.
Changes from v6 to v8:
* FWUPDATER removed almost completely. Think nobody will need that.
* NETCF is of v3.5.
* VGA mode is back in IE.
* Internet sharing is working now.
* Sim Toolkit changed. Can't test it, cause have no STK on my sim, so waiting for tests...
* Changed POWER MANAGEMENT of x500+. So I'm expecting test results of battery life e.t.c. (probably it will be a bit less). BUT it menas that WIFI will be working even on suspended device. GSM stability is also improved (as for me).
* Changed SD parameters. It may affect RAM but it also increases speed... So, again waiting for tests...
* Added separate cab 'Allow suspend' so everybody who need a little bit more battery may switch to old power scheme. (do not recommend by myself...)
* Added cab which changes gsm drivers priorities. You may expect a better time response. (probably...)
* Added cab with old wavedev.dll. It may fix low sound in speaker (please test it and report to me, thank!)
* Other small fixes.
Changes from v5 to v6:
* Small fixes in registry (SD card is not detached on suspend e.t.c.).
* Obex is turned on now by default.
* Created special cabs (at the bottom of the post) with different versions of gsm drivers. You may try them in case you have problems with gsm.
* Small fixes in kernel - removed unused driver.
* After long testing page pool changed to 6MB. As for me, I can't see any performence lost.
ROMS:
x500+ shift sequel v9 eng (mirror)
Additional soft:
USSD Handler (mirror). By default usual MS ussd behaviour is on. But you can't answer on ussd request. This patch solves the problem.
MMS Composer (mirror). By default MS do not have software for mms. This is default soft from eten for that. Think is good. (you must launch \Windows\CSP.exe after installing composer)
GSM drivers (mirror). You may try several versons of gsm drivers in case you have problems with stk or gsm.
Old GSM Drivers Old eten 'get log patch'. This patch updates gsm drivres to old version, but may solve STK problems.
SD large blocks (mirror). This patch enabled larger block transfers for SD card. It may improve sd card speed.
Windows Live. Windows Live in cab.
You'll have to install by yourself all other soft (eten standart soft for example).
download
http://www.edisk.cz/stahnout-soubor/05924/ROM_WM61shift_sequel_v9.zip_35.57MB.html
