Creating product data items list
Product data items list created
Backup not required
Flashing phone
Initializing
Scanning image files...
Waiting for USB device...
Loading secondary boot code: 15168 bytes
Secondary boot loaded
BB Asic Index is: 00
Asic ID is: 000000030000022600010007600C192102031104
EM Asic ID is: 00001040
EM Asic ID is: 00001060
Public ID is: 0A10011191DE03447E4F9302ED59404B9E2534EB
Asic Mode ID: 00
Hash: 916F75217F32081248B15C38DFC8E81B
ROM ID: E693EF0DAC22615B
Device type is: 05
Device Index is: 00
Manufacturer code: 0000
Device ID: 0000
Extended device ID: 0000
Revision ID: 0000
Device type is: 04
Device Index is: 00
Manufacturer code: FFFF
Device ID: 0000
Revision ID: 0000
Device type is: 00
Device Index is: 00
Manufacturer code: 0020
Device ID: 0040
Revision ID: 0031
Device type is: 00
Device Index is: 01
Device ID: 0001
Revision ID: 0000
Device type is: 03
Device Index is: 00
Device ID: 0040
Revision ID: 0031
Loading update server code: 868528 bytes
Update server loaded
Asic CMT: Start programming 133058 KB...
Asic CMT: Programming data sent: 0%
Asic CMT: Programming data sent: 10%
Asic CMT: Programming data sent: 20%
Asic CMT: Programming data sent: 30%
Asic CMT: Programming data sent: 40%
Asic CMT: Programming data sent: 50%
Asic CMT: Programming data sent: 60%
Asic CMT: Programming data sent: 70%
Asic CMT: Programming data sent: 80%
Asic CMT: Programming data sent: 90%
Asic CMT: Programming data sent: 100%
Programming complete
Asic CMT: Verifying communication to device...
Waiting for communication response: 25
Waiting for communication response: 24
Waiting for communication response: 23
Waiting for communication response: 22
Waiting for communication response: 21
Waiting for communication response: 20
Waiting for communication response: 19
Waiting for communication response: 18
Waiting for communication response: 17
Waiting for communication response: 16
Waiting for communication response: 15
Waiting for communication response: 14
Waiting for communication response: 13
Waiting for communication response: 12
Waiting for communication response: 11
Waiting for communication response: 10
Waiting for communication response: 9
Waiting for communication response: 8
Waiting for communication response: 7
Waiting for communication response: 6
Waiting for communication response: 5
Waiting for communication response: 4
Waiting for communication response: 3
Error 0x8401F121 communicating to phone. Unable to verify comm.
Warning: Unable to communicate to product after flashing
Starting to recover the phone
Recovering phone
Initializing
Phone recovery completed. Waiting for phone to boot up
Bootup successful
Verifying communication to product (before flash finalizing)
Failed to verfy communication to product
ZDE SE OBJEVÍ HLÁŠKA O NUTNOSTI ODPOJIT A PŘIPOJIT USB
OBJEVÍ SE CHYBOVÁ TABULKA – POKUD ODPOJÍM USB – PŘIPOJÍM A RYCHLE STISKNU RETRY OBJEVÍ SE
Communication verified
Data restoring skipped
Stopping all operations, returning phone to default mode
All operations completed
Firmware updating succeeded.
To je nejdále kam jsem se dostal, firmware mám ve správných složkách, zkoušel jsem jich asi dvacet, včetně přímo pro toto produktové číslo (je to verze pro DE), vyzkoušel jsem všechny pro CZ distribuci, EURO 3 I skandinávskou verzi. Telefon se mi flešnout nepodařilo, I různé kombinace stisku tlačítek zapnutí při probíhajícím fleši – nic nepomáhá, verifikace se nikdy nezdaří. Telefon se po připojení do PC zahlásí na 10 vteřin jako neznámé zařízení a pak se odpojí. Shodou okolností jsem včera tímto způsobem flešoval jinou C5-03 s jiným produktovým číslem a tam se verze firmware. Firmware stahuju přes placenou verzi Navifirmu.
Napadlo mě vyzkoušet fleš přes JAF, jenže tam jsem narazil na problem, mám jádro RM-697 a to není podporováno, na kartě MCU jsou potřeba soubory ve formátu CMT a já žádný takový soubor přes navifirm ve firmware nemám. Existuje způsob jak ten telefon flešnout přes JAF? Našel jsem jen hacknutí již stávajícího upraveného firmware.
K dipozici mám ještě RIFF Jtag box – bohužel ho mám krátce a učím se s ním, C5-03 nemá rozhraní pro JTAG, má rozhraní MBUS co jsem tak pochopil, na RJ45 konektoru boxu jsou tyhle piny:
1. 4.2V
2. UART TX
3. UART RX
4. UART TX2
5. MBUS
6. PROBE
7. BSI
8. GND
Po studování netu jsem zjistil, že ten konektor používá každej na přídavný napájení, nenašel jsem nikoho, kdo by přes to flešoval C5-03 s jádrem RM-697 I když podle pinů vše naznačuje tomu, že by to jít mělo. Telefon je mrtvý, po stisknutí tlačítka jen zavibruje. Třeba někdo poradí. Bohužel nevím co se dělo s telefonem před tím a nemůžu vyloučit hardwarovou závadu, ale podle sdělení předchozího uživatele byl vadný firmware.
Odkazy:
https://www.google.cz/search?q=riff+jtag+rj45+pinout&biw=1680&bih=892&source=lnms&tbm=isch&sa=X&ei=PWMmVNCgJdPiaNqDgvgE&ved=0CAYQ_AUoAQ#facrc=_&imgdii=_&imgrc=LNJ5uBbr5YanBM%253A%3Bdid07s_KqC5kLM%3Bhttp%253A%252F%252Fwww.jtagbox.com%252Fdownloads%252Fmanuals%252Friffbox_pinout.jpg%3Bhttp%253A%252F%252Fsrimeenakshimobiles.com%252Fforums%252Ffront-page%252F27975-riff-box-jtag-manager-version-1-17-jtag-pins-detection-added.html%3B763%3B494
https://www.google.cz/search?q=c5-03+pinout&biw=1680&bih=892&tbm=isch&imgil=MPvZowddK1fEUM%253A%253Be0QDF9p8AMOj7M%253Bhttp%25253A%25252F%25252Fwww.gsmeye.com%25252Ff39%25252Fall-nokia-fbus-pinout-picture-here-1324%25252Findex3.html&source=iu&pf=m&fir=MPvZowddK1fEUM%253A%252Ce0QDF9p8AMOj7M%252C_&usg=__Ep7zuPxNICYnZZAMdTFsxHqgi_w%3D&dur=372#facrc=_&imgdii=_&imgrc=c0TNLw-PAx6z-M%253A%3Bxb62mTZEeMU8pM%3Bhttp%253A%252F%252Fi48.tinypic.com%252F30cnntd.jpg%3Bhttp%253A%252F%252Fwww.gsmeye.com%252Ff39%252Fall-nokia-fbus-pinout-picture-here-1324%252F%3B438%3B505
