Instalace:
just copy and paste the 2 folders on the root of your SD card... then try to run it from your sd card if it doesn't ruy by itself. It will ask you for a activation key... there is a keygen folder in the zip file... run the keygen... enter your device number in it... it gives you a activation key. enter the activation key on your phone and you're good to go ! oh and copy and paste the maps in the root of your sd card as well
http://rapidshare.com/files/18804950/TT6_Tested_on_Treo_650_and_works__.rar
