Requirements: Smartphone
Overview: Facade is a highly customizable tab-based Home screen plug-in for Smartphone devices. With Facade, you can view your upcoming appointments and tasks directly on your Smartphone Home screen, keeping you up to date on all your important appointments and tasks. Additionally, Facade puts a launcher tool right onto that same Home screen, allowing you to launch your favorite applications directly from your Home screen with just a single click and monitoring your Smartphone battery and memory status using special meters.
* New method for reloading home screen
* Fix email retrieval (and duplicate tmail.exe), seen on some devices when home screen reloads
* Support variable width buttons depending on format and button state
* Add support for rocker/spinner keys (when included in the hardware)
* Correction to left side separator line when using separators and textIndent
* New "battery2" option for devices which don't support battery details
* Allow nonstandard CPU types such as SGH-i200 devices
* Show date headings even when no future appointments exist (for weather forecasts)
* Fix missing battery charging image
* Fix randomly missed tasks when "Max lines" is exceeded by task count
* Fix "default" tab setting when buttons and tabs are combined
* Fix problem with png transparency rendering
* Support png files without transparency information
http://www.ziddu.com/download/8111968/F148.rar.html
