Požadavky: iOS 6.0 or later. Compatible with iPhone, iPad, and iPod touch.
No more dots in your calendar! myCal PRO displays what you need to see, your events! myCal PRO is THE BEST replacement for the internal iDevice calendar app!
https://userscloud.com/37tuv7jdwfy6
https://dailyuploads.net/1zdsretor8l8
https://dropapk.com/zj9vh064ipcg
For example: add new calendars for Work, Home, and Sports and optionally set the colors to Red, Green and Blue respectively. Simples!
◆◆ NEW: Better Facebook event support. You can now hide declined events! ◆◆
◆◆ Time Zone support! ◆◆
◆◆ Cut, Copy and Paste options!! ◆◆
◆◆ List View!! ◆◆
◆◆ Powerful scrolling week view! ◆◆
◆◆ Invitee support! ◆◆
◆◆ Additional contact dates can appear as events! ◆◆
Create beautiful calendars just like these screenshots!
* Day background colors or images requires an InApp purchase. Event background colors is included, no InApp purchase required.
Check out the feedback we have been getting in the AppStore reviews:
"Best scheduling tool I've used so far! Great app and support. Highly recommended!"
"Love this on my iphone4s, ipod4, and ipad. Perfect and easy to read. This is the PERFECT replacement for the useless calendar on the iPhone & iPod. This is what Apple should have used."
"they added the Week view. I didn't know I needed it and now it's my most used view! Thanks guys"
Also myCal PRO has been reviewed at thesmartphoneappreview.com, given a whopping 91% and is 'Highly recommended'!
Supports iOS4.3 and above, iPhone 3GS/iPod Touch 3rd Gen and better, and all versions of the iPad!
◆ Powerful event repeat options, any number of days weeks, months or years. Second Thursday of every 3rd Month for example!
◆ AirPrint support! 2 finger swipe down the screen on any event view! Print in portrait or landscape, depending on the device orientation!
◆ Support for additional contact dates! see anniversaries etc that have been added to a contact as read only annually repeating events!
◆ Enhanced Month View that displays actual events (all day, multi day and timed)
◆ Enhanced scrolling Week View with horizontal or vertical day layout and the option to display multiple lines for an event
◆ Invitee support, you can now receive and acknowledge invitations, as well as send your own (iCloud and GMail calendars)
◆ Customize the width of the weekend in the Month View to make your working week larger
◆ Enhanced Day View that displays much more detail including title, location, calendar name with hyperlink, reminder, birthday and repeat icons
◆ Supports both Landscape and Portrait, with full screen options for each
◆ Uses the internal calendar as its database, no additional syncing required. Any iCal subscriptions already created will be visible in myCal PRO
