Veškeré programy pro Apple iPhone (AppStore).
14. 01. 2017 07:57
Bluetooth Keep Awake
Bluetooth Keep Awake v2.2 patched
20,-Kc
4.2 a vyšší
Popis: When you experience disconnects from your bluetooth devices like bluetooth keyboard, mouse, barcode scanner, audio device, health device etc., try this! This app MIGHT be a solution to keep the connection to your bluetooth devices active.
https://play.google.com/store/apps/details?id=net.mybesttools.bkeepawake
https://dropapk.com/g7dxqx6hdjdv
http://userscloud.com/5ires3r8jb9s
Please do not expect this app to make all problems vanish in thin air. It provides a possible solution if connections are not stable for you. Comments like ' It does not work' do not help me in finding a solution. You can always send me a proper description of what does not work for you, in which case I would be happy to look into it.Again, please do not give unfounded bad reviews, think of your karma Dotazy na SZ.
