Požadavky: iOS 9.3 or later. Compatible with iPhone, iPad, and iPod touch.
Screen:Czech TV + je aplikace pro kontrolu rozhlasových a televizních pořadů v Čechách kdykoliv a kdekoliv. Sledujte své oblíbené přehlídky a programy, nastavte alarmy, když se vaše oblíbené přehlídky vysílají!
https://upload4earn.net/c0uqoaavc020
https://userscloud.com/rg0ay0lojskh
https://dailyuploads.net/wfr8myp0z6yf
● Support for a total of 108 TV channels (Czech Republic and others)
● Live TV streaming support for a few TV channels
● AirPlay support
● Time schedules shown using your local time zone
● Ability to check TV schedule from anywhere, anytime
● Easily find and track reruns and all episodes of a series by setting it as a "Favorite"
● There can be a lot of useful data for a show: description, duration, actors, directors, country of origin, screenshots, IMDb WWW link, etc.
● You can search by channel, category or a keyword
● Shows are categorized heuristically in one of these categories: Movies, TV Series, Documentaries, Animated, News, Entertainment, Music and Sports
● Movie subcategories: Comedy, Western, SF, etc.
● Application has to be paid only once, but you can use it on as many devices as you want
ALERTS:
● Ability to receive an alert before the show is on air: up to 2 hours before the show
● Alerts can be received even when the application is not running or you are offline
● Automatic rescheduling of alerts if show schedule changes
● Support for recurring alerts that trigger every time your favorite show is on air
● Alerted show are visible in a calendar of your choice
FAST & TRANSPARENT:
● All data downloaded from the network can be used offline for later use, so you can use this application even when you are offline
● TV listings are downloaded for up to 20 days in the future
● TV listings are downloaded in the background, so application is fully functional while downloading
● Multitasking support: when application is put into background it will continue downloading and processing if needed
● Support for dual cores using Grand Central Dispatch technology
● iCloud support: list of selected channels and list of favorites are stored in the cloud and shared between all your iOS devices
LOOKS:
● All application views work in both portrait and landscape orientation of your device
● Retina Display high resolution graphics support
Icons by Joseph Wain / glyphish.com http://glyphish.com
Support website: https://sites.google.com/site/iosapplicationssupport/
If you like this application, please leave a review on iTunes App Store!
DISCLAIMER:
● We own all intellectual property rights to the software. However, we do not claim ownership to the channels and contents which ownership is held by the site to which the software links.
● This software doesn't maintain any channel servers but only uses the channel servers that are available on the web. Sometimes server feeds are turned off, not available or just bad quality. We have no control over the Internet feeds used by this application.
● If owners of any specific channels don't want the channels to appear in this application, please send your request to our email to remove them from the application. But, if owners of any specific channels have any concerns regarding law, please contact either the entities claiming the servers mentioned above.
● Channels offered may vary and may be withdrawn without prior notice depending on the availability.
● We own the right to modify these terms at any time, which modification shall be effective immediately upon posting
