Požadavky: Android 2.2+
Photo Mate Professional is your first choice when it comes to viewing and editing (raw-)images on your tablet or smartphone!
What features do you get?
* Viewing images (including raw and psd images) in high quality
* Editing images with xmp-sidefiles support
* Batch-Converting + Renaming and applying editing on a bunch of images
* File explorer with support for video thumbnails and multi-select
* Support for image ratings and filtering (with support for XMP)
* Support for XMP-Keywording
* Histogram-View to check the tones + lightness of your image
* Possibility to mark over- and under-exposured areas
* Frequent updates with new features
* Free direct support to the developer if you have problems
Current supported File Formats:
jpg: Full Resolution + Exif
png: Full Resolution
ico: Full Resolution
psd: Depending on Filesize Full Resolution (max Size ~20MB) or thumbnail
tiff: Depending on Filesize Full Resolution or no image
cr2 (Canon Raw): Full Resolution + Exif
nef (Nikon Raw): Different Resolutions + Exif
arw (Sony Raw): Full Resolution + Exif
rw2 (Panasonic Raw): approx. 2 MP
orf (Olympus Raw): approx. 2 MP + Exif
dng (Digital Negativ, Raw Format): Depending on "inner" file type + Exif
pef (Pentax Raw): approx. 1 MP
3fr (Hasselblad Raw): thumbnail + Exif
raf (Fuji Raw): Different Resolutions
mrw (Minolta Raw): Approx. 0.3 MP
x3f (Sigma Raw): Approx. 4 MP
erf (Epson Raw): Approx. 0.3 MP + Exif
Since we have introduced the editing capabilities, a lot of users were very happy to have such a great tool on their mobile device.
- So we're proud to announce that we've extended the editing capabilities!
- The next version will offer an option to shift whitebalance and the image tone. This is very useful for wrong-colored images.
Please note that this setting won't be compatible with Adobe software, since it would lead to wrong results.
https://play.google.com/store/apps/details?id=com.tsgames.pictureinfoKód: Vybrat vše
http://www28.zippyshare.com/v/26989251/file.htmlKód: Vybrat vše
http://www.embedupload.com/?d=9RINJFGDGD
http://uploadmirrors.com/download/QVFYPJIZ/0p7a9s.apk
