(48,- Kc)
Popis: Create smooth stop-motion animation and time-lapse in minutes, on the move - anywhere.
Fix rotate screen during import bug
3.8
Import images
Preview loop
Large swipe gallery
3.7
Tablet layouts
3.6
Ability to record audio for movies
Fixed crash after hi-res playback
3.5
Bug fixes in camera options and playback
3.4
Improved options and UI
3.3
Fix for Nexus S 4G
3.2
Clap Trigger (requires audio permission)
Video sharing (YouTube, Facebook, Gmail etc)
3.1
Added details to movie list
Standard resolution export option
Fix Galaxy Tab on 3.2+
https://play.google.com/store/apps/details?id=jal.clickstudio.mainpackKód: Vybrat vše
http://uloz.to/xKKyBw2G/clayframes-v3-9-4allmobile-eu-apk
http://www8.zippyshare.com/v/14570658/file.htmlClayframes is easy to use and has a rich set of professional features for making stop-frame animation (or claymation) and time-lapse movies.
Please try before you buy: Clayframes Lite is the free trial version. Try making a movie with the Clayframes Lite demo app before buying to confirm compatibility with your device.
Clayframes includes these powerful features:
* Onion-skinning (transparent overlay) for smooth movement. Align the current shot with the previous one.
* New! * Preview Loop: Review your movie as you shoot it! Make fast progress without stopping to review.
* Trigger camera shutter remotely using a hand clap or the phones proximity sensor. Avoids camera shake.
* Timed shutter release option for time-lapse movies. Any interval from 1 second to 1 hour.
* Add audio using the microphone on your device. Record your own vocals, effects or soundtrack.
* New! * Import images.
* Edit ANY frames; add and remove frames at any position in your movie. Get that timing just right.
* Add to your movie at ANY time; add more frames to older movies.
* Adjust playback speed (frames per second) at any time.
* Quick single frame duplication and deletion.
* Copy, reverse and delete clips of frames or the whole movie.
* Review slider gives quick navigation and touch controlled playback speed.
* Choice of image resolution; including HD.
* AVI (mjpeg format) video exporter.
* Share your video directly with email, YouTube or Facebook.
* Play the whole movie or selected clips, without exporting.
* Compact app can be installed on SD card.
