(53,- Kc)
Popis: Wifi Inspector is a simple tool to see all the devices connected to our network (both wired and wifi, whether consoles, TVs, pcs, tablets, phones etc ...), giving relevant data such as IP address, manufacturer, device name and MacAddress.
v1.1
- Fixed minor bugs
https://play.google.com/store/apps/details?id=lksystems.wifiintruderproKód: Vybrat vše
http://uloz.to/xNSn9bcE/wifi-inspector-pro-v1-1-4allmobile-eu-apk
http://www24.zippyshare.com/v/97791759/file.html
http://www.tusfiles.net/817yzdyxowyt
http://www.kingfiles.net/jyoizv32km5p/Wifi_Inspector_Pro_21.apk
http://unlimitzone.com/xkcvhgp4op1s/Wifi_Inspector_Pro_21.apk.html
http://hugefiles.net/3pmzirla39l6Wifi Inspector is a simple tool to see all the devices connected to our network (both wired and wifi, whether consoles, TVs, pcs, tablets, phones etc ...), giving relevant data such as IP address, manufacturer, device name and MacAddress.
Wifi Inspector also allows to save a list of known devices with custom name and find intruders in less than 30 seconds. This makes it easier for us and you will not need to go checking the data whenever we make a scan.
All this in a clear and simple design that allows us to see that our personal data are safe in a few seconds.
No doubt, Wifi Ispector ALWAYS find ALL connected devices!!
Please if you have any problem with Wifi Inspector Pro, do not hesitate to email and we will gladly work to fix it.
Pro Version without advertising
languages
- Spanish
- English
- Italian
For a better experience we recommend Android 4.0 or more
