WorkShift Agenda
08. 07. 2016 00:56
WorkShift Agenda
WorkShift Agenda v1.4.0
73,-Kc
Požadavky: Android: 3.1 a vyšší
Popis: Essential and intuitive calendar for shift workers and busy people, with shifts, notes, overtime, wage, reports and recursive alarms.
https://play.google.com/store/apps/details?id=mxb.projects.wsagenda
https://ulozto.cz/!2UyfBAGnZ/workshift-agenda-4allmobile-eu-apk
https://ulozto.sk/!eUCsSboEA/workshift-agenda-4allmobile-eu-apk
https://ulozto.net/!7gBoUw2r9/workshift-agenda-4allmobile-eu-apk
https://sdilej.cz/7871032/WorkShift.Agenda-%5B4allmobile.eu%5D.apk
Essential and intuitive calendar for shift workers and busy people, with shifts, notes, overtime, wage, reports and recursive alarms. Organize the work shift or your appointments with a few clicks, setting all the alarms you need.
Also use it to remember to get your pills and know at a glance when your cycle days will comes ... or keep track of your favourites TV series with dedicated alarm!
WorkShift Agenta supports shift profiles, so you can have more shift planning simultaneously, and synchronize with different calendars.
Each day of the calendar can be configured with the color of the related shift, and will have a customized alarm-clock that will always ring at the right time. Also you will able to set-up wage per hour for overtime work and regoular shifts.
Use the REPORT function to have a record of your wage, with percentages, totals and average pay.
Four usefull widgets will show you shift and notes, while a notification icon let you to know the first note and shift ahead.
A data management section provides many different options to backup, share and distribute your shift informations trough txt files, cloud space and synchronization with Android Calendar.
